It is currently Fri Oct 31, 2025 5:12 pm
 Post subject: more wiring ????
PostPosted: Mon Jan 11, 2010 6:03 am
ok so im looking at all these check conectors i have, and i come to the conclusion i dont have the self diagnose check conector, is that the obd1 port. the only thing i can think ill need it for is data logging right? so when i get my data logger cable can i just hard wire it in, also what about the rest of the check conectors, do any of them go to the data logger? just another attempt at starting a thread that has been done a thousand times... no really i tried the search, really i did... thanks
 Post subject: Re: more wiring ????
PostPosted: Mon Jan 11, 2010 11:35 am
Your car is not OBD1. It's actually a system made my mitsubishi. People hook up a palm pilot (or other equivalent) to read the onboard diagnostics. You only have to plug into that diagnostic connector to get a wealth of information, so that's the only place you really need to use the datalogger for. If you haven't located it yet, it's down below dash on the driver's side, and adjacent to fuse box. You don't need anything fancy beyond an analog voltmeter, if you are just trying to pull error codes stored in the ecu.
There is fuel pump test connector on the firewall of the engine bay. Also, an oxygen sensor test connector by the ecu. Those are the only two "test connectors" I know of.
Good stuff - trucks bring it!
PostPosted: Mon Jan 11, 2010 12:10 pm
ya it doesnt even exsist on my car. all good though like i said im sure looking at the manuals i can find a way to hard wire the data logger in. thanks
PostPosted: Mon Dec 20, 2010 7:03 am
I read you said theres a test connector for oxygen sensor and a fuel pump connectors. Where are these exactly please and also what do i hook to them to figure out if there bad or good please? I wish we had pictures of exactely where these and other connectors are and what to hook to them and look for if there good or bad...charleyturbo.
PostPosted: Thu Jan 06, 2011 8:56 am
^^^ The factory service manuals are located here, and detail everything in picture format: www.lilevo.com/mirage/
This has been gone over many times, these posts should be in the Newbie section if they are not 4g61/63 TECHNICAL based please.
