It is currently Wed Oct 29, 2025 1:02 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page 1 2 Next
 Post subject: I picked up a new car
PostPosted: Tue Nov 17, 2009 10:30 pm
I will try to get the pics up on it shortly but here is the mod lis
Mods:
Engine:
-6Bolt 2.3L
-4G64 Crank
-ARP Headstuds
-ARP Mainstuds
-ATI Super Harmonic Damper
-Manley Rods
-Wiseco 8.8:1 Pistons .020
Head:
-Crower Retainers
-DV/DT Coil On Plugs
-Fidanza Cam Gears
-Ferrea 1mm Oversized Valves
-HKS 272/272 Cams
-HKS Springs
-MLS Headgasket
-Power Enterprise Timing Belt
-Shaved Valve Cover
Turbo:
-Borg Warner S372
-DV/DT Fabrications 4" Turbo-Back Exhaust
-Shearer Fabrications T4 Top Mount Exhaust Manifold
-Twin TiAL 38mm MS-V Wastegates
Intake:
-DV/DT Fabrications FLP Intake Manifold
-DV/DT Fabrications Intercooler w/ 3" Piping
-DV/DT Fabrications 5" Intake Pipe
-Q45 Throttle Body
-70mm CNC Throttle Body
-Twin Tial 50mm Q Blow Off Valves
Drivetrain/Suspension:
-TRE/PPG Dogbox
-QM Twin Disc Clutch
-Cross Drilled and Slotted Rotors
-Eibach Lowering Springs
-KYB GR-2 Shocks
-Enkei RPF-1 SBC 17x8.5 +30mm Offset
-BFG g-force T/A KDW 2 235/40/17
Fuel:
-Twin DV/DT Fabrications Fuel Rails
-FIC 1600cc Injectors
-FIC 650cc Injectors
-Fuelab 515 Fuel Pressure Regulator
-Fuelab 818 Fuel Filter
-Magnafuel ProTuner 750 Fuel Pump 4303
-10AN Black Nylon Fuel Line
Electronics:
-AEM EMS
-AEM 5 Bar Map Sensor
-AEM AIT Sensor
-AEM Boost Control Solenoid
-AEM Wideband
-Defi Boost Gauge
-Defi Fuel Pressure Gauge
-Dyantek ARC-2 Ignition Box
Misc:
-Battery relocated to the trunk
-Blitz Turbo Timer
-Koyo Aluminum Radiator
-New Paint
-Prothane Motor Mounts
-Moroso Oil Catch Can
-A/C
-P/S
My friend which is not to smart bought the car drove it. spun a rod bearing in the motor. I picked this car up for a fraction of what it cost to build I mean that to :D
PostPosted: Tue Nov 17, 2009 10:32 pm
I also on the deal got a magnus rear tube sub frame for the rear end which cost 2500 from magnus them self.
PostPosted: Tue Nov 17, 2009 10:49 pm
Looks good but I would try to find a bigger turbo. :lol:
PostPosted: Tue Nov 17, 2009 10:57 pm
I belive on the break in dyno tune at 16 or 18 psi it made 404 whp and like high 360tq I belive. maybe lower the sheat is some where around gere spools really good to or did. befor the motor problems :(
PostPosted: Wed Nov 18, 2009 10:40 am
Very nice! I'm good friends with Albert (the guy who runs DV/DT), we grew up together. His parts are awesome. Did you by any chance by that car from a dude named Kevin?
PostPosted: Wed Nov 18, 2009 12:35 pm
My friend bought it from a guy in IL I bought it from my friend. The guy he bought it from has been a very big dic*. he tryed contacting him to ask simple questions. and he would never get back to us.
PostPosted: Wed Nov 18, 2009 12:39 pm
Only reason I ask, I knew a guy named Kevin that had a 2g Talon that he was building up using a lot of Albert's parts, so I was wondering if it was the same car. The dude was in Illinois too. Got any exterior shots of the car?
PostPosted: Wed Nov 18, 2009 1:43 pm
You're gonna shoot your eye out!
PostPosted: Wed Nov 18, 2009 9:05 pm
ha na I wont shoot my eye out. It is a 97 talon!!!!!!!
92 Colt swap sold
91 Eagle talon gt4202 powerd stock block 26psi
97 Eagle talon way to many mods to list
PostPosted: Thu Nov 19, 2009 10:52 am
Ahh ok, this isn't the car I was thinking of. Still freakin' sweet though.
PostPosted: Thu Nov 19, 2009 11:01 am
Sweet? That thing is a f'in BEAST!
PostPosted: Thu Nov 19, 2009 11:12 am
Until he gets some numbers out of it, it's just another clean 2g with a lot of go-fast parts on it...
PostPosted: Thu Nov 19, 2009 11:54 am
True...true
PostPosted: Thu Nov 19, 2009 12:31 pm
lol u guys are crazy if u dont think it can't do it. I on the other hand do not have the extra cash laying around to completly build the motor the way I want it to have . I would like to sale the hole 2.3 setup if anyone is intrested. I am a 2.0 guy. it also has a built 2g head. From what I was told the 2g heads are better at helping with spool up. I desided I am going to use some stock mitsu parts I had for now. 1g rods with t he evo 9 pistons had the rods honed for 22mm wrist pin all arp in the motor. I think I would like to try to take this block to 60awhp. I belive it would be somthing that has not been done atleast yet. I know there is a couple of guys dynoed high 570whp or so but they had there cars in fwd mode. I think the forged 8.8:1 evo 9 pistons will help this out.
Tyler,
PostPosted: Thu Nov 19, 2009 12:34 pm
lol u guys are crazy if u dont think it can't do it. I on tjhe other hand do not have the extra cash laying around to completly build the motor the way I want it . I would like to sale the hole 2.3 setup if anyone is intrested. I am a 2.0 guy. it also has a built 2g head. From what I was told the 2g heads are better at helping with spool up. I desided I am going to use some tock mitsu parts I had for now. 1g rods with t he evo 9 pistons had the rods honed for 22mm wrist pin all arp in the motor. I think I would like to try to take this block to 60awhp. I belive it would be somthing that has not been done atleast yet. I know there is a couple of guys dynoed high 570whp or so but they had there cars in fwd mode. I think the forged 8.8:1 evo 9 pistons will help this out.
Tyler,
Never said you couldn't do it. Honestly though, having a set up like that without a built motor is a complete waste if you ask me. I'm a 2.0 guy also, although a long-rod 2.4 is a pretty bad-ass setup also, I would never run a 2.3 stroker ever. You're gonna want to run a LOT of boost to take advantage of a turbo like that, and you simply can't do that on stock rods without seriously risking things. It might work for a while, but if you make one mistake with your tuning it's game over. Build it once, build it right, be done with it.
