It is currently Thu Oct 30, 2025 1:06 pm
 Post subject: Rear upper strut mounts
PostPosted: Wed Jun 10, 2009 4:24 pm
Since Trevtec found out that evo iv rear strut mounts were the same as csm's, I got a set of Tein pillow ball mounts for the rear of the mirage. Best part is that they are set up for 2.5 coil over springs.....
scot
PostPosted: Wed Jun 10, 2009 7:54 pm
I thought it was the evo8 rear struts that fit? And what are the advantages of running the pillowball mount?
PostPosted: Thu Oct 14, 2010 10:09 pm
Did you ever end up fitting these?
PostPosted: Fri Oct 15, 2010 7:43 am
These do fit, I have them installed on my car right now. But mine are Workz from japan , haha had to get that mad tyte jdm. so go ahead and buy them all the evo parts are the same that I used.
PostPosted: Sat Oct 16, 2010 2:43 am
Are you using Evo 4 or 8 mounts? I've got a set of Galant VR-4 pillowball mounts which look pretty close to fitting, but want to know what my options are if they don't work out.
PostPosted: Sat Oct 16, 2010 9:58 am
will work:
galant
Evo3
Evo8
Wont work:
Honda lol :P
PostPosted: Sat Oct 16, 2010 8:29 pm
Thanks man :wtg:
PostPosted: Fri Oct 22, 2010 11:13 am
would also this fits the CSM sedan right? what part number are this on TEIN
