It is currently Thu Oct 30, 2025 4:30 pm
 Post subject: 4G15 4 speed auto tranny
PostPosted: Sun May 31, 2009 12:18 am
How strong are they in comparison to others hooked up to other DSM engines? I realize this sounds completely noob but it fits since my summit has this engine and tranny. Guess what I'm asking is can they take a little slap and tickle or are they too wimpy for mild highway fun?
PostPosted: Sun May 31, 2009 12:24 am
mine broke from about 110 hp. Although I did drop shift it. It will brake with 200+ hp and you will get crappy gas milage. If your going to use a dsm engine just grab the auto tranny with it.
PostPosted: Sun May 31, 2009 11:51 am
Of coursed this tranny is made for this engine and when I do the swap it will be replaced with the swap tranny as well. I do want to stick to a 4 speed auto if possible. For example, I go with a 4g63t with a matching 4 speed auto "turbo" tranny, it should be ok with 250 hp? I dont want to go hog wild with this, just enough to make the ricers and wannabes run away crying. I can make up for lack of power with a little skill, luck, and insanity :supz:
Upgrades I know I will be doing will be the 4th gear clutch pack, possible valve body, and diff for sure. Did I miss anything? 8)
PostPosted: Sun May 31, 2009 4:39 pm
you should be fine with 300hp as long as you upgrade the tranny cooler. someone on the board removed the tcu and just had shifts, I forget who that is though.
PostPosted: Sun May 31, 2009 6:55 pm
Nah, I will keep the TCU, perhaps look for upgrades but basically keep it stock. The big things I know of are clutch packs, valve body, torque converter and the diff. Most certainly the diff! :supz:
I will definitely move the tranny cooler from the rad to an external unit. Maybe run special tranny fluid, as long as it doesn't fry it in the process. Does royal purple have a tranny fluid that I can use? I am a little leary because with my old wagon (R.I.P.), I put some Lucas tranny stabilizer in it and it never worked right since.
PostPosted: Sun May 31, 2009 7:46 pm
just use the recommended stuff, sounds like you have had enough with the snakeoils. nowadays the standards of auto fluids are pretty high. though you would benefit from a complete system flush and or teardown of a auto tranny.
PostPosted: Sun May 31, 2009 8:10 pm
Agreed. Dont need it going boom when I am trying to lay it down.
PostPosted: Sun May 31, 2009 8:44 pm
Stock 1G AWD autos are pretty stout. I'm pretty sure people have went 10's on them, stock converters with probably a shift kit.
PostPosted: Sun May 31, 2009 8:59 pm
I am keeping it FWD only for now to keep the cost down. Keep in mind I fried an AWD O/D clutchpack once doing 90mph in 3rd and hitting the switch at full throttle. The poor bugger in the gran prix was shocked because I still beat him
PostPosted: Sun May 31, 2009 9:02 pm
Still can use an AWD trans. Stronger, shorter gears better for drag racing. Need to weld the center diff and remove the VCU.
Easy
PostPosted: Sun May 31, 2009 9:05 pm
I will consult with Jeff when we start swapping. I wont be as hardcore as you were, just enough to scare off punks and maybe raise a few eyebrows. Its all about budget this time I'm afraid.
PostPosted: Sun May 31, 2009 9:12 pm
Haha. Well it's a good tidbit for you to know regardless. Throw in a nice aluminum cooler and you'll be good to go.
PostPosted: Sun May 31, 2009 9:21 pm
I showed some friends of mine your video today and they looked at my car and just drooled. Friggin hilarious.
PostPosted: Fri Aug 07, 2009 11:25 am
i got a cyclone engine 4g15b its a cabby engine but i plan to put in a 4g63t soon and keep my tranny what mods will i have to do to the tranny to handle that power
