It is currently Sun Oct 26, 2025 7:58 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
PostPosted: Sat Feb 07, 2009 4:56 pm
http://www.4g61t.org/gallery/v/members/ ... e+Section/
All photos located in the folder above, more need photos taken.
Some of the items for those interested include:
1G turbo cylinder head from running motor - sitting a long time, needs to be cleaned up, I can check it if someone is interested - ie flat edge, etc.
91 CAS plug style not pigtail - $35 CAN
1G or CSM K&N air filter $10 CDN - clean but no foam tape, came from my car
1G fuel rail $10 CDN with modded inlet barb for push on fuel hose
1G 450cc injectors $35 CDN :supz:
Retainers for door cards $5 CDN- pop in clips to retain door cards
1G FMIC $20 CDN- pitting on hose contact areas - JB weld or weld it and call it a day - cleaned inside and out by yours truly - car had no boost leaks before being pulled apart
MBC - basic hardware store unit, was holding 15-18 psi for PO
93 Elantra ECU harness pigtails$10 CDN- approx 12" of ECU harness plugins, great for bad ECU harness pins (bad retension or corrosion) could be spliced into any 89-93 CSM, 90-94 DSM or 92-94.5 Elantra, possibly 4g15 apps for Hyundai like the Excel, Sonata, etc from same time frame. :supz:
4G15 MPI relays and flasher units
4G15 TCU's for CSM's (89-92)
4G15 alternator
4G67 MAF Hyundai or Mitsu 1.8L NA DOHC 4g67 MAF in working order
4G61 MAF Hyundai or Mitsu 1.6L NA DOHC 4g61 MAF in working order
4G63t 1G MAF $10 CDN(have honeycomb to put back in)
4G63t AWD starter $15 CDN
91 Talon Cruise control cables and diaphragm and motor pack
91 DSM pop up headlamp motors - worked fine when pulled
91 harness's added:
ECU to Engine $50 CDN :supz:
DASH harness $30 CDN
ENGINE BAY fuse block along front rad support wiring $30 CDN
Laguna pond equipment - including pumps, hoses, filters, and lenses to setup an inground lagoon, or waterfall to a pond. If your interested, I can give you part numbers and I'm sure they have a website we can reference to.
Quick rundown for those interested in anything. I want this stuff gone, so will accept highest bid or only bid, cannot sit on this stuff anymore. I will be dumpstering almost everything listed unless I can actually use in on my turbo car later. There are Elantra brakes and 91 Talon brake parts not shown that make a nearly complete system for either one, if anyone is interested in local pickup or shipping on parts of the package.
I will only charge actual shipping and have lots of boxes hanging around. I don't have alot of packing material so I may have to get creative with cardboard and packing tape. :twisted:
I don't care what I have to accept for a price offer, just make it worth my while to get to the mail depot (Canada Post Outlet) and I'll be happy with most small items. I may hold off for all bids to come in on larger/more expensive items, but if you pay through Paypal, I will consider it sold if we can agree on a price.
Sorry about the quality of the pictures, cell phone instead of boinked/dropped camera. :-?
For shipping I can't get estimates for everyone unless I know your 5 digit (US) or 6 Alpha-numeric (CAN) ZIP codes so send those my way. I will be shipping parts VIA CANADA POST, and if you want the cheapest route possible, with or without insurance, let me know that also. I dont have time to take individual items down to the post office, so I use the online calculator, with weights and sizes and destination ZIP to confirm roughly what your cost is on shipping.
Any questions, just ask.
PostPosted: Sun Feb 08, 2009 10:19 pm
Nobody needs 450 cc injectors or an Elantra brake booster to upgrade their stock CSM unit?
Start throwing out some prices or I'll have to list some suggestions that we work from. :axe: :P
I think I may add the 91 DSM full engine bay and interior harnesses to this once I find out their condition.
PostPosted: Mon Feb 09, 2009 5:14 pm
More pics added, sorry they suxor because of the new/old camera I borrowed.
1991 AWD Talon Harness include:
Engine to ECU harness, couple of wires were spliced into for an SAFC it looks like.
Engine bay fuse block (minus the block because it is a pita to remove) that runs across the rad support and up onto the passenger side fender area (wiring for pop up lights, side markers etc)
Dash harness from the junction blocks across to the fans and console areas.
These harnesses did come from an ABS equipped car, so that is all there too. 99.9% of the connectors are intact and have been kept clean and acclimatized since they were pulled. This came from a running car with no known issues before it was stored.
PostPosted: Tue Feb 10, 2009 6:13 pm
Cleaned up post and added some pricing to work from. 8)
