It is currently Sun Oct 26, 2025 7:42 pm
 Post subject: Oil Restrictor
PostPosted: Mon Aug 04, 2008 12:09 am
Since my ss oil feed line is coming off the head, do I need to run an oil restrictor fitting? This is for a Precision BB 60-1 with the Mitsu exhaust housing. Also this turbo is for my 1.6L, if that helps. Any help is appreciated. Thanks!
PostPosted: Tue Aug 12, 2008 4:25 pm
Most ball bearing turbos will need a restrictor. But you should verify with the supplier. Here is a decent discussion on the subject, even though it is initially about 20G turbos.
http://www.dsmtuners.com/forums/newbie- ... ictor.html
PostPosted: Tue Aug 12, 2008 4:46 pm
Thanks, but I already called Precision and talked to their technicians. I got the oil restrictor fitting I needed! :D
