Too many cars at the house have to clean up
Brand new engine, with break in miles only haven't hooked up wastegate yet>
-1.6 sohc, 8 Valve G32BT
-.030" Over new ITM pistons
-rods and mains .010"
-Reliefed oil passages for extra flow pressure
-Block decked
-Head Decked, ported and chamber cleaned of all sharpies
-SDS EFI EM2-4F with DSM 390cc injectors. No more old crappy DIZZY coil packs and all the tuning you could want
-255lph Intake walbro, 10 ga wiring with relay in back in battery box
-Custom machined/built TIG welded Intake manifold
-56mm TB
-Blitz BOV
-2" Boost piping
-WRX TD04L turbo
-custom front mount intercooler <core 24" x 8" x 2.5" thick
-3" intake suction piping with large K&N filter
-Custom top mount header ceramic coated Titanium Color
-Custom downpipe 2.5" turbo out, 2" wastegate out, joins into 3"
-Full 3" mandrel bent exhaust, magnaflow 3" straight thru muffler
- Hella Air horn kit
-MOMO steering wheel on custom adpater
-Custom seats mounted low, reupolstered 2 tone. Rear seat custom done, extra foam added, cut down and shaped to match fronts <liek buckets in back
-Clarion CD/MP3 sirius head unit
-Alpine splits Tweets high mount in door 6.5" lower in door. Cross over in behind
-AEM Wideband gauge and sensor
-Boost gauge
-Oil pressue Guage
-Autometer TACH
-Custom lightened Flywheel, ACT Sprung 6 puck clutch <brand new
-Custom breather tank
-New radiator from Suzuki swift gti with low pro haden electric fan
-Powder coated factory 14" turbo wheels
-New vented front rotors, new pads, and calipers
-Custom coil overs, thread over kit installed. Custom upper spring mount and thru chassis mount. KONI yellow single <5> adjustable struts in custom housings to fit Colt
-UHMW bushed trouque rod from body to tranny
Needs new owner and some paint!!! Well I like the sleeper look so good enough for me
$4000cdn
Pics here
http://groups.msn.com/holyshift/dodgecolt2.msnw
http://groups.msn.com/holyshift/dodgecolt2.msnw?Page=2
