It is currently Sat Nov 01, 2025 9:03 pm
 Post subject: 4G63T IN 93 MIRAGE COUPE
PostPosted: Mon Mar 24, 2008 12:10 pm
ok i have a question. i have done the awd 4g63t swap on a 89 colt hatch. is the wiring the same, engine harness wise. on the 93 mirage coupe?
PostPosted: Mon Mar 24, 2008 12:19 pm
No.
PostPosted: Mon Mar 24, 2008 1:20 pm
Everything changed just enough to make it a slightly different car inside/outside. The 1.5 litre in a 93 was MAP based so wiring will be different for the interface and connectors from that end. Check the pinouts from a 93 ECU - might be listed here: Click Me
PostPosted: Mon Mar 24, 2008 1:56 pm
My 94 LS coupe.....
http://s4.photobucket.com/albums/y141/g ... rage%20LS/
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
 Post subject: ...
PostPosted: Mon Mar 24, 2008 2:18 pm
so does anyone have any good info on the wiring of the harness inside the car to give the mpi relay power?
PostPosted: Mon Mar 24, 2008 2:52 pm
Use the factory manual and find the wires that are live from the ignition switch when the key is in the "run" position, and the start wires to connect that part of the system, and you are a go. It's all detailed in the manual as to what wires are power or not at various points of key function.
PostPosted: Mon Mar 24, 2008 3:44 pm
thanks for the help man
