It is currently Mon Nov 03, 2025 3:09 pm
PostPosted: Tue Jun 12, 2007 4:30 pm
Car- 94 Mirage Sedan
Motor-4g63
Transmission- 97 GST FWD
Problem- I want to run Turbo Mirage axles or 1g AWD axles, I know the size of the 2g axles diffrent and that I can not use them for my swap. Can I swap in a 90-92.5 FWD diff and use the older axles? It is best for me to use the 2g tranny for mount placment.
PostPosted: Tue Jun 12, 2007 7:32 pm
Yep, use the early FWD diff or any AWD diff. Just swap over your ring gear to the new diff and reshim it and you're done. I believe the 2g tranny will work in the 4g's however I don't know if you use the tranny mounts from the dsm or the Mirage. You can use a 1g tranny as well but you'll have to fabricate rollstops. I guess if you're converting to AWD this will have to be done anyway though.
PostPosted: Tue Jun 12, 2007 8:51 pm
Staying FWD, Im gonna try the roll stops from a 1.8 5 speed. I think I will check CAPS and see if the roll stops interchange from Eclipse to Mirage.
PostPosted: Tue Jun 12, 2007 10:12 pm
I know the mounts and roll stops are the same between a 1.5 and 1.8 4g (manual tranny) Mirage but I highly doubt they are the same as the 2g Eclipse.
