It is currently Wed Oct 29, 2025 10:57 pm
 Post subject: JDM Cyclone ECU Question
PostPosted: Thu Mar 08, 2007 8:40 pm
I just got a JDM Cyclone motor. The number on the ECU says its from the 87-89 GVR4. The thing is the wiring harness is cut. Can I use a wiring harness from any 1G DSM?
PostPosted: Fri Mar 09, 2007 2:57 am
Yes, but some of the sensors may be different, depending on what year harness you use, and I am not sure if the pins on the cyclone ecu correspond with the usdm harness.
PostPosted: Fri Mar 09, 2007 8:10 am
Thats kind of what i figured. Any idea where to find a pin out for the GVR4 ECU? If i could get the harness from a 90 would i needa swap sensors? And what about the cyclone intake?
PostPosted: Fri Mar 09, 2007 9:07 am
www.galantvr4.org
