It is currently Sun Oct 26, 2025 3:39 pm
 Post subject: AWD Mirage Alignment
PostPosted: Sat Jan 20, 2007 5:23 pm
I just wanted to share my latest alignment results
Front
Camber- I have DSM camber/caster plates. They don't work ideally with the Mirage. Both camber and caster are pushed all the way positive. Not much I can do there until I figure out some better plates. I would love more caster. I also want camber to be around -1.5*
Rear
This subframe has brand new poly bushings and bolts. Welded active toe. Everything freely adjusted. Welding in the rear subframe mounts while ON an alignment rack would have been perfect, but my garage tape measure alignment was close enough to retain the ability to adjust back to spec.
Pre-alignment
Post-alignment
LILEVO1 alignment
PostPosted: Sat Jan 20, 2007 6:48 pm
1595 cc's of fury
Not bad at all for tap measured frame work. Just dropping my Mirage 1.5" caused it to have -1.9 camber in the front. Good work.
