It is currently Mon Oct 27, 2025 12:01 am
 Post subject: rough idle, no revs
PostPosted: Mon Feb 20, 2006 7:28 pm
I just finished my swap. 61T in my 91 colt. it idles rough and wont rev past about 5. try to drive it and it falls on its face. please help. oh yeh, props to my brother darkhorse for making my swap possible. thanks bro
2012 Explorer Limited
1989 Colt GT clone 4G63t auto
1992 Talon TSi
1990 Talon TSi
1995 Crown Vic
1993 Ford F-250 BBF
1987 Chevy Sprint Turbo
PostPosted: Mon Feb 20, 2006 9:28 pm
is it getting fuel? I had a fuel pump go bad on me once and it did that.
PostPosted: Tue Feb 21, 2006 10:49 pm
Done the basic leak test to assure no boost leaks?
PostPosted: Wed Feb 22, 2006 2:25 pm
no boost leaks. I robbed a bunch of shit from my talon (fuel pump, piping, etc.) so I know I'm getting fuel.
1992 Talon TSi
1990 Talon TSi
1995 Crown Vic
1993 Ford F-250 BBF
 Post subject: Re: rough idle, no revs
PostPosted: Wed Feb 22, 2006 6:27 pm
What ECU and what MAF are you using ?
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Thu Feb 23, 2006 6:03 am
Somehow I think it's either air flow related or an ignition issue.
Got rabies?
PostPosted: Fri Feb 24, 2006 7:02 pm
CSM O.G.
he is using a 89GT motor, harness, 90 DSM MAF and 89GT ECU...all my old swap goodies since I am no longer building a clone :twisted:
maybe I should loan him my 90DSM ECU...to go along with my 90 throttle body from my donor 4g63...and give him my Elantra front brakes to go with the GT rears...
some parts that I'd like to find still...KM210 (he is using the F5M22 from 1.8 eclipse) and turbo axles (good luck, I know)
do you think it could be the CAS?
I am WAY too nice
~joe
PostPosted: Fri Feb 24, 2006 10:27 pm
Nobody Important
Do those play well with each other? I thought they were different. AKA either go with a turbo CSM MAF or up the injectors to 450's and run a DSM ECU.
PostPosted: Sat Feb 25, 2006 12:12 pm
The Mad Scientist
Usually with a rev limit that isn't expected its due to bad ignition coils or bad spark plugs. Too much of a gap and not enough power to ignite it fast enough ect.
PostPosted: Sat Feb 25, 2006 5:11 pm
Nobody Important
Yeah, but I don't think the CSM MAF has the same output as the DSM one. The ECU is tuning for a DSM sensor but it is actually from a CSM one. That statement is totally valid IF you are using the correct sensors and whatnot. We have other factors here.
I am positive that info is on the site somewhere, but I'll leave that search up to the pony ;)
PostPosted: Sat Mar 18, 2006 2:28 am
thank you guys for all of your input. i did go with a dsm ecu and it solved all my problems. thanks again for the support and the info
1992 Talon TSi
1990 Talon TSi
1995 Crown Vic
1993 Ford F-250 BBF
PostPosted: Sun Mar 19, 2006 7:50 am
Stealthpony, I may be interested in that 61T ECU. I have another project in the making.
Darin
1986 GMC 3/4 Ton 4x4 Diesel (soon to be Greasel)
1993 Colt GL
PostPosted: Sun Nov 23, 2008 5:54 pm
I think this is the same problem i'm having on one of my swaps. I have a dsm ecu, with a 61 mas. It revs up to like 1500 and falls on it's face. But I can unplug the maf and rev it up just fine.
I'm going to try a 1G maf now.
PostPosted: Sun Nov 23, 2008 6:16 pm
How are you enjoying your new Mirage Mike
PostPosted: Sun Nov 23, 2008 8:18 pm
I'm actually selling it, since i got my summit running.
