It is currently Tue Oct 28, 2025 1:09 am
 Post subject: what are the odds??
PostPosted: Fri Oct 15, 2004 8:55 pm
.. of the pistons being destroyed when the timing belt lets loose? i have another head but i'm worried about the bottom end. i was going about 25mph when the timing belt decided to spit off all the teeth around the crank pulley...
PostPosted: Fri Oct 15, 2004 10:55 pm
pistons will probably be fine. But I WOULD worry about the rods and bearings. That is still quite a bit of stress.
1989 Mirage Turbo 4g63T w/ small 16g just bolted in so far.
LSD, 1g flywheel/clutch.
1989 Colt GT 4g61T (63T build in progress)
1g ECU, Injectors, Exhaust manifold, 16g evo III Turbo, SMIC, and C Exhaust cam -9*
K&N Air filter, airbox cut up, MSD plug wires, NGKs, Apexi S-AFC II, MAF translator, tubular o2 housing w/ dump tube, Full 3" mandral.
Now I ran out of fuel!!
