It is currently Sat Oct 25, 2025 4:59 pm
Post new topic  Reply to topic  [ 57 posts ]  Go to page Previous 1 2 3 4
 Post subject: Re: Suspension ASAP
PostPosted: Wed May 16, 2012 12:31 am
I just read through this whole thread and it doesnt have a freakin ending to it!
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Wed May 16, 2012 3:07 am
lol That's how things go sometimes here.
PostPosted: Wed May 16, 2012 6:13 am
I just installed a set of K Sports on my car, and although I've only put 25 miles on it or so, I think it made a world of differnce. No cutting, just bolt and go!
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed May 16, 2012 11:13 am
Keep us posted, I'm interested in these. Can you select different spring rates? I assume you are on the softest setting?
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Wed May 16, 2012 11:31 am
Just like my last 3 or 4 build threads :lol: . Maybe it's a North Carolina thing.
PostPosted: Wed May 16, 2012 11:44 am
My dealer told me you can change spring rates for roughly $50 when you order the coil overs, or you can buy them later for $50 each... I decided to go with what they came with. The rears are sleeved down, and looks like they would work on an AWD rear end (if you removed the sleeves). I haven't adjusted them at all, other than the install/height. I know they are not on the softest or hardest, because I checked one of them to see if it would adjust either way, then I just put it back the way it was. I probably should put them on all the way soft, then see how I like it as I adjust them up. Either way, I also did SuperPro bushings up front and Yoshi Fab sway bars at the same time, so I'm sure that helped as well.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed May 16, 2012 6:29 pm
So it's not too rough? I'm a little worried because I heard they were but the feedback I got wasn't very detailed. I don't want to rock a kidney belt in a street car.
edit: It would be for my fwd stock turbo car.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Wed May 16, 2012 8:21 pm
I'm driving some 1300 miles in it next month. I should be able to do a decent review then!
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed May 16, 2012 8:59 pm
I look forward to it!
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Sat May 19, 2012 5:36 pm
Pics! we need pics! i have gr2s with b&g lowering springs and i still want to go lower. How flexible are the height settings on them?
1991 Plymouth Colt - Project
PostPosted: Sat May 19, 2012 6:56 pm
I dont have them down all the way, and its as low as I want it. There isn't much to show in a picture of them, they look like any other coil over... There is a pictrue of them in my Rally Dixie Thread.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun May 20, 2012 1:14 am
Thanks! That's a nice looking ride you got there too! Lol im gonna start saving for these. But the talon is getting paint first. :D
