It is currently Tue Oct 28, 2025 12:10 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Nov 02, 2010 12:41 am
so what about reinforcing the rear bar? like welding on more material?
Welding springs doesn't work very well. What's wrong with the DSM bar like the OP used?
welding can be done for little to nothing in cost,
PostPosted: Tue Nov 02, 2010 9:41 am
Then you'll be in the market for a whole rear suspension piece, and getting those bolts out of the bushings is harder than it looks. It looks impossible by the way.
Cheapest would be to leave it alone.
PostPosted: Tue Nov 02, 2010 11:52 am
^ He is right
I ended up cutting the bolt out and drilling the holes out to 1/2" bolts and welding plates onto the chassis moutning points to make it stronger. I then cut derlin bushings and new stainless steel sleeves for the rear trailing arm bushings. Next I did weld plate steel to my trailing arm to double the thickness, Even with all of this I am going to run a rear sway bar. Keep in mind I have 400lbs springs in the rear plus KYB AGX on soft, I am really hoping to have one of the meanest time attack suspension setups out there with sticking FWD and stock appearing suspension.
