It is currently Mon Nov 03, 2025 3:12 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Nov 16, 2008 2:30 pm
Where would you put it on the thermostat housing? Thanks for any help! :D
Two vacuum lines connect to a plastic heating fitting on the housing, replace that with the fan switch.
PostPosted: Sun Nov 16, 2008 10:26 pm
Awesome! I don't even use those nipples, they are capped off from eliminating my emissions. I have a honda aluminum radiator and I was wondering about the fan switch. Thanks! :D
PostPosted: Fri Nov 21, 2008 12:54 pm
Well, it passed an alignment this morning. Started driving it a bit harder on the way home, there is a crazy vibration after letting off the gas in the upper rpm range. The drive shaft does not appear to be hitting the sway bar (the clearances are really close there), so I think the drive shaft must be flexing a bit. I am going to look into smaller carrier bearings for the drive shaft, I dont want the huge dsm stock bearing back in it.
