It is currently Tue Oct 28, 2025 9:59 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Mon Jan 07, 2013 2:59 pm
is the clutch an oem replacement for the 1.6 flat flywheel or for a stepped dsm flywheel?
if it is flat, the swap to a stepped dsm flywheel and a stock type dsm clutch could easily hande another 100lb/ft of torque.
fwiw, a fwd dsm flywheel will work fine, i never had any problems running one in my km210 trans.
and the clutch will last a long time, even at a higher torque rating. mine lasted fine, til i snapped the 3/4 shift fork with it in 4th gear. the drive home through red lights finished the clutch off.
PostPosted: Mon Jan 07, 2013 4:07 pm
Thanks for the compliments guys. I try really hard to resist going crazy with the car because it HAS to be my reliable daily driver first. I just refuse to drive something everyday that's a bore to drive. I drive 100mi a day and fuel is expensive here which is why I want to keep mileage at 40mpg, no less if I can help it.
I may try a big turbo someday but for now I guess I'll focus on body work that I want done. I still think I can gain even more economy with a landspeed style front fascia and side skirts.
I'd like to get some lapping days in at The Ridge this year, it's close to my house. I might do some 1/4mi runs but what's the point unless I buy slicks. I don't care to run any 14.5@115mph runs. Ha.
PostPosted: Mon Jan 07, 2013 4:13 pm
It has the flat 215mm setup, not the stepped DSM one. It's an Exedy OEM replacement. I have a new fwd DSM stepped flywheel already so when this clutch goes I will just upgrade then. I'm still not sure if I like the f5m33 tranny I recently installed. I may rebuild the km210 and put that back in instead. I'm going to do some economy testing with smaller diameter tires to see if I get better mpg with higher or lower rpm.
PostPosted: Sat Feb 02, 2013 5:15 pm
[quoteI put my Colt on the dyno recently and I'm just looking to see if there is any room for improvement. Here are the specs: 1.6L with Wiseco 10:1 pistons, 1.8L head (small combustion chamber with 1g 2.0L size runners), HKS 264/272 cams, 2.0L intake & TB, 2.5" ic pipes, Supra smic, small 16g, 1000cc hi-Z injs, walbro 255, 3" downpipe, no cat and 2.5" full exhaust, Link V3 on speed density with/dual maps for E85 and 92oct. I think that's about it.][/quote]
Which pistons are these? Are the an off the shelf Wiseco? what is the bore and compression?
PostPosted: Sun Feb 17, 2013 1:44 pm
Any updates I would also like to know the details on the pistons
PostPosted: Sun Feb 17, 2013 2:00 pm
I have tried three times since you posted this up to go and grab a dyno sheet. With the holidays the place I dynoed the 1.6L has been in and out a bunch. I am going to try again monday for you.
Have you found the time yet and what did you answer on the other forum?
PostPosted: Sun Feb 17, 2013 9:32 pm
The pistons were custom made by Wiseco. None of the piston manufacturers had made any 10:1 4g61t pistons before. The valve reliefs are big enough for 272 cams, I don't know the specs. I had them moly coated skirts. I don't know anymore of the specs, English Racing built the engine.
PostPosted: Wed Feb 20, 2013 11:45 pm
I just keep forgetting. I have not made it a priority.
1985 Mitsubishi Cordia
Build in progress
PostPosted: Sat Mar 09, 2013 5:22 pm
Here is what my little 1.6L did through an automatic transmission. This is what the curve on it looked like. Stock DSM turbo cams, 14b turbo, all stock 4G61 N/A motor from valve cover to oil pan(9.2:1 compression). The cams and the turbo were all the mods that car had. And I only put the cams in because I had to do a timing belt on it. The cams were .01" taller on the lobes.
Build in progress
