It is currently Fri Oct 24, 2025 10:04 am
PostPosted: Sun May 11, 2003 6:07 pm
The 4G15 is a very easy motor to work on so I would suggest you build the motor yourself. You will still have to get the machining done by a shop of course but actually putting it all together is very easy.
Performance pistons can be a little hard to source but that's OK since there is an easy option for that. The Hyundai Excel X1 ('86-'89) uses flat-top pistons which brings the CR up to ~10.5:1 and already 'eyebrowed' for a multivalve head (if your going to use the 12v head) and they are readilly available.
The rotating assembly is in desperate need of balancing, as I think little is done at the factory. I noticed a huge difference in my old 4G15 with all the top end harshness disappearing it would rev and make good power all the way to stock rev limit at ~6800rpm.
Hyundai excel x1? is the x1 a normal excel or some other option? I work in a salvage yard with plenty of old excels. What would this car be designated in the U.S.?
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Sun May 11, 2003 7:34 pm
socrateez:
X1 Excels are just the first generation excels so and US spec first gen excel is a X1
PostPosted: Mon May 12, 2003 6:28 am
thanx for the info! Seems like a possible upgrade.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Mon May 12, 2003 7:33 am
4g61t Delinquent
hey socrateez hows youe come up with your "short-ram" intake?
I own a CSM.
PostPosted: Mon May 12, 2003 7:50 pm
Pretty simple really. All i did was cut away the air can except for the part that actually holds the filter in place. Then K&N filtercharger. The tube is aluminum 3" diameter from any 80's volvo turbo. You can find plenty of them in junk yards real cheap. Just cut what you need its about a foot long with a few bends and a straight section.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
