It is currently Thu Oct 23, 2025 6:25 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Thu May 03, 2012 9:35 pm
You'll have CRAZY vibations at higher RPM/Speed
Is that the only downside? If so I can live with that lol. It's not a luxury car its a ugly little car that im trying to make go fast in a straight line.
PostPosted: Thu May 03, 2012 10:14 pm
Making the mounts takes literally a half hour. Some angle iron and you're good to go.
PostPosted: Fri May 04, 2012 6:36 am
Those vibrations will cause damage to your drivetrain, I was told by a driveshaft shop a drive shaft that long would have to be over 3" diameter and really thick wall tubing to keep it from flexing and chucking itself on the pavement, 2 pc shaft at least, 3 pc is better from what I've learned
PostPosted: Fri May 04, 2012 8:38 am
After talking to driveshaftshop and Henderson (a local driveshaft place) they both said that I could not get away with a 1pc shaft, and needed 2pc at minimum.
1990 Colt AWD 8.8
PostPosted: Fri May 04, 2012 9:47 am
Hmmm thanks for the info guys.
Any one have a link to how a stock Dsm drive shaft is shortened? There is not much info on the drive shaft part. Or atleast I couldent find any.
PostPosted: Fri May 04, 2012 11:34 am
most people use the front (short shaft) and the carrier bearing.. they remove the other 2 rear pieces and put a single in there.. what this does is comes off the x-fer case like stock..then a sigle back to the rearend. there was a few I seen in the build threads over the years but no time to look as im off to work in a few.. if u dont find them ill look this weekend..
PostPosted: Fri May 04, 2012 6:23 pm
Thanks ill look around.
PostPosted: Wed Oct 10, 2012 11:44 pm
After a highly regreted partout , the colt is back in business.
PostPosted: Thu Oct 11, 2012 3:11 pm
Did you sell parts from the colt or another car to fund the colt?
1985 Mitsubishi Cordia
Build in progress
PostPosted: Thu Oct 11, 2012 7:24 pm
I sold everything from the colt. Motor, turbo, trans, ecu and fuel set up. I wish I dident tho.
PostPosted: Thu Oct 11, 2012 10:02 pm
All this has to go back In to car. I got the car in a pile. I was going to do a fully striped car and not out this Stuf in ,but I'm at the time in my life where I want comfort lol so heat, seats , carpet and all go back in.
Harness is in
PostPosted: Fri Oct 12, 2012 12:45 am
thats alot of stuff.
PostPosted: Sat Oct 13, 2012 12:04 pm
Finaly got everything in and the Dsm shifter installed where I want it. It even fits under the colts center section.
PostPosted: Sun Oct 14, 2012 6:56 pm
I spent today on the outside of the car. Spent a good 5 hours trying to bring the shine back, I think it looks good now especially for sun beaten , oxidated 24 year old paint. We washed ,clay bar, wash again ,buffed then waxed it.
Before
After
Before
After
Before
After
Before
After
PostPosted: Sun Oct 14, 2012 8:18 pm
Looking good! I need to wash/wax/clay bar mines Aswell :) glad to see her saved! :rock:
