It is currently Thu Oct 23, 2025 12:15 pm
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
 Post subject: Re: Mirage90's Build
PostPosted: Mon Apr 30, 2012 12:09 am
Because Race Car
I'm no help with your starter issue but I have to say that I love those 240 wheels on a Colt! Car looks great :supz:
Thanks man. I am debating if i should paint them black?
As for the starter issue, i have found the problem. Battery was bad. ](*,)
It's always something simple lol. Were you able to get it recharged and started or get it going with another battery?
I wouldn't paint them because if they were black you wouldn't be able to see the holes. Just my $.02
PostPosted: Mon Apr 30, 2012 2:13 am
Replace it with a known good battery turned over first time.
I had doubt in painting them. I will just leave them alone. I am going to buy new ones for it eventually.
PostPosted: Mon Apr 30, 2012 11:12 am
Break, brake... it's all the same phonetically.
On my first swapped Colt it took me three days to figure out why the starter wouldn't hit, it was a single wire connector just like that one that was hiding. Glad to hear you have the thing turning over!
PostPosted: Mon Apr 30, 2012 11:59 pm
Im having starting issues. Its turning over, I have fire, I know the ECU is good. Ive tried two good ECU'S, It is in Time. Double check it. Its got GREAT compression. Im getting fuel. A good friend came by to help and he double check everything and he knows its in time. He notice #1 and #2 spark plugs wasn't firing and strong as #3 and #4. Could it be a bad coil pack?
Here is a video.
https://www.facebook.com/photo.php?v=34 ... eo_comment
If you cant see the video, add me as a friend.
Its a 90 4g63t block and head. Im not running a turbo right now. I have a 1990 turbo harness I have N/A injectors, and a 4g63 N/A ECU "Known good".
PostPosted: Tue May 01, 2012 9:09 pm
could it be the N/A ecu u trying to use?
PostPosted: Tue May 01, 2012 10:18 pm
Ive used 90 Turbo ECU, it was good. I used at 1.6 95 Elantra ECU, Then a 90 N/A ECU known good also.
PostPosted: Tue May 01, 2012 10:45 pm
Well i got it started. I didnt have the CTS hook up. Plug it in, and it started right up. Only problem now is, Its bogging out and dieing when i try to give it gas.
PostPosted: Wed May 02, 2012 6:37 am
CTS?
PostPosted: Wed May 02, 2012 11:59 am
CTS?
Coolent Temp Sensor.
PostPosted: Fri May 04, 2012 11:10 pm
Well i have solved the problem. Some plugs where cut from my harness.
Got new plugs from the junkyard. Plugged everything up and it starts and runs now! :supz:
I have to wire in my 2G MAS sensor...
I not 100% on swapping from 1G to 2G.
Im using this...http://www.vfaq.com/index-main.html
Not sure if its the same. My 1G MAS plug on has six wires, and the one the website shows has 8 wires.
Here is my 2g MAS, I got the plug off a 94 Expo, and the 2G MAS came from a Mighty Max.
PostPosted: Sat May 05, 2012 1:40 am
Another update. Im having problems with the clutch. I don't think the clutch is engaging. I believe i might have a bad throw out bearing. I'm going to drop the tranny tomorrow and change with a new one, and go from there. Anybody have any clue why i can not get it into any gears.
I bled the whole system. I dont understand.
PostPosted: Sun May 13, 2012 10:31 pm
is the slave moving all way when you push in the clutch? Did you adjust shift cables or adjust clutch pedal? after market pp/clutch? I have to drop my trans again cause i forgot to shim pivot ball, I have aftermarket pp/clutch, I can shift but I dont have that free play and it engages before released all the way..
PostPosted: Sun May 13, 2012 10:40 pm
I've fix the problems. I replace the throw out bearing, and install 94 Elantra Shift cables "with adjustable turnbuckles" in the car.
I am running stock turbo clutch and Fly wheel. Turbo FWD tranny with CSM Shift leavers welded on.
PostPosted: Sun May 13, 2012 11:07 pm
shifts good now? Was gonna say maybe check clutch master cylinder to?
PostPosted: Sun May 13, 2012 11:38 pm
Master and slave cylinder are new.
Yes it shifts into every gear. I got a little grinding in 2nd, im thinking scyros are going out.
