It is currently Fri Oct 24, 2025 7:25 am
Post new topic  Reply to topic  [ 40 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri Sep 03, 2004 12:38 am
There aren't any labels on that Tb.. I think it would be a better way to search for TB with the same sensor connectors, Could you tell what label should be on 4g37 Tb -Mikuni or Mitsubishi to bolt it without any difficulties?
Maybe the core is the same meaning the main aluminum casting? the ISC and idle stop circuit are probably the plastic housing we see. The connectors are just like the timing connector and 02 sensor wiring but most people have the push on connector with the little metal clip for retention purposes. I think he may be able to disassemble both throttle bodies - 1.5L and 1.8L alike and see what fits back onto the new throttle body. I believe much like the C10 seats bolting into my C50 chassis that the throttle body will be much the same casting.
Could you post up whether:
A) the TB has a Mikuni label or Mitsubishi label
B) any Mitsubishi part numbers # listed on the TB
c) any numbers listed on the grey plastic(?) housing on the side.
I think it is possible that c62_drive needs to backwards engineer the TB to accept the old sensor castings onto the new TB.
Mitsubishi Lancer C60 sold
Mitsubishi Colt 4G93
PostPosted: Fri Sep 03, 2004 6:02 pm
Going down to check my TB right now .....
"Made in Korea"
My old (1.5L) one said Mikuni I believe. The one I got came from a Hyundai Sonata here in North America. The labelling in the end may mean nothing depending upon where the parts were sourced to provide assembly for cars headed to certain regions of the world.
Best bet is to take your old tb or find an old one at the yard and compare to a Sonata TB or similar 4g37 SOHC model engine and find the one you need; the connectors will be the same but you may or may not find the TPS sensor in the same twisted position, I had to remove part of my old TPS tang? (metal rod) that operated or provided the twisting force against the sensor an swap it over. That's about it except for swapping the full (known good sensor) ISC and zero throttle sensor bracket with my good sensors attached. Your ideal setup will be to just plug one or two extra vaccuum lines top and bottom and pretty much plug and play. Make sure to get the bigger gasket ie. the one for a 1.8L SOHC engine and if you have the time and know how- definitely port match the intake to the TB.
PostPosted: Fri Sep 03, 2004 10:47 pm
"made in korea" is what ive seen on all the Hyundai made Mitsu parts.
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Sat Sep 04, 2004 12:48 pm
Thanks for your help!!!
PostPosted: Mon Sep 06, 2004 2:43 am
I have a 4g15; just what are the bennefits to putting a 5mm bigger throttle body on it? :o
90 Eagle Summit 1.5 - Wrecked
92 Eagle Summit 1.5 - Sold
94 Talon TSi AWD Auto - Sold
PostPosted: Mon Sep 06, 2004 11:34 am
better throttle response, a slight increase in top-end performance, and improved acceleration. On a 12v engine, your probally talking a couple hp improvement without other mods. On the 8v engine, maybe 1 hp since the porting is so small that volumetric efficiency isnt improved very much. The 12v engine has much larger porting while using the same throttlebody.
Think of four-barrel carb vs two-barrel carb
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Tue Sep 07, 2004 1:37 am
Thanks for the quick response. I'm looking into it, so if you could help...
1. Where could I pick one up? (4g67 TB, that is)
2. How is installation?
Thanks,
JD
PostPosted: Tue Sep 07, 2004 5:08 am
any junker that has a 1.8L eclipse would have it :-p
and it's 4 bolts in, out and boom you are done ;-)
err... i forgot about the coolant lines that connect to the TB, so 4 bolts, and 2 clips holding on the 2 lines on the TB and boom you are done :-D
01 Maxima VQ30DE
92 Summit 4g63t (Traded to Evo... R.I.P.)
I heard they ride mooses to work instead of driving cars. (About Canadians.)
PostPosted: Tue Sep 07, 2004 10:16 am
dont forget to port the intake too, or you'll get minimal benefit.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Tue Sep 07, 2004 10:37 am
Thanks fellas.
PS - How do you port your intake?
PostPosted: Tue Sep 07, 2004 11:03 am
it's still awesome without a ported intake, I have a ported intake, which is going on today, so i'll tell ya how much more it kicks ass :-D
01 Maxima VQ30DE
PostPosted: Tue Sep 07, 2004 8:34 pm
OK. :P
PostPosted: Wed Sep 08, 2004 6:15 pm
Enough to break the wheel loose on a hot day that wouldn't have happened before. You can get to the point of burning the stock clutch slightly, well enough to smell that you didn't let out on the clutch fast enough from a STOP-1-2 Shift.
The system leans out slightly as more air, both metered and unmetered, is being drawn in under all cirumstances but overall I have found that idle stabilizes just as quick when the ECU learns again due to battery removal, accelerating is better and bypassing the coolant lines that go to the TB can help ward off ping as long as the engine is kept moving and the air/engine don't become heat saturated too much. Once the motor is baking at stop lights, the motor likes to ping when part throttle until things cool abit in the air tract and further down the chain. I surmise a thermstat that opens a little sooner may a help here but haven't bothered and now things are cooling down again. I have tuned using cheap 87 octane and it doesn't do anything for performance but the motor really does love higher octane with the compression we are running. Don't bump your timing or play with the timing cam trick until you have things settled and figure out your aren't running badly because you can compound problems very quickly when tuning; the only reason I am leary of tuning the only car I can afford to drive of the two I own!
It might be a time to think about an Octane switch soon .... hmmm.
PostPosted: Wed Sep 08, 2004 7:36 pm
Hi there!
U guys in the US sure do have a lot of 2 door Lancers ( U call them Colts, I think).
I have a 5 door hatch CA 1990 Lancer with 4G15 8v. Very rare to find a 2 door in Land of Oz.
I have been told that one cannot swap the T/B on a 4G15 8v coz it will stuff up the ISC motor. I was told not to even think about boring it out :(
Anyone got any "juice" on this??
"May the Force be with u........Always".
PostPosted: Wed Sep 08, 2004 10:22 pm
Flying Eagle, better octane fuel is definately reccomended if you are modding. Especially when you alter mechanical timing events. Retarding cam timing slightly raises compression levels as does advancing ignition timing. As i'm sure you realize at this point, all this requires higher octane due knock occuring easier. With my mods i can run 89 octane at stock ignition timing with 4-1/5* of cam retard. With 7* ignition advance, i require 91 octane-which is where my current setup is.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
