It is currently Fri Oct 24, 2025 10:25 pm
PostPosted: Sat Oct 23, 2004 10:38 pm
89 1.5l 8v colt
There doesn't seem to be any marks on the crankshaft pulley for me to check timing...can someone give me a referance point from maybe the 4 bolts holding the pulley on? There is also two holes on the inner part of the pulley-1 is filled in and the other is cut out if that helps. Please Help!!!!!
PostPosted: Sat Oct 23, 2004 11:53 pm
there is a reference mark on the inner timing pulley behind the crank pulley. It matches a mark on the block.
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Sun Oct 24, 2004 12:39 am
Thanks for the info! Didnt want to have to pull everything but after looking at one of your posts about the timing belt being loose i took a closer look at mine. Maybe its causing my other problem...? I am dumbfounded.
