It is currently Sat Jun 15, 2024 4:25 pm
Post new topic  Reply to topic  [ 130 posts ]  Go to page Previous 1 2 3 4 59 Next
PostPosted: Wed Mar 10, 2004 10:35 am
Are you using the software off the site you posted? I have the hotsync cradle, a male plug, then soldered the rest together, just one 10k ohm 1/2 watt resistor, and one diode. I would get a reading every now and again, but it would be wrong, like 18.1 battery, 7900 rpms, but I'd get them just for a second. So you used that same schematic? Arrg.
1989 Mirage Turbo 4g63T w/ small 16g just bolted in so far.
LSD, 1g flywheel/clutch.
1989 Colt GT 4g61T (63T build in progress)
1g ECU, Injectors, Exhaust manifold, 16g evo III Turbo, SMIC, and C Exhaust cam -9*
K&N Air filter, airbox cut up, MSD plug wires, NGKs, Apexi S-AFC II, MAF translator, tubular o2 housing w/ dump tube, Full 3" mandral.
Now I ran out of fuel!!
PostPosted: Wed Mar 10, 2004 10:40 am
And if that't the only cable that needs to be made, what's the deal with the schematic on the PDA site?
PostPosted: Wed Mar 10, 2004 10:43 am
Can you give me specs on the anode/cathode and resistor you used. Maybe i don't have right ones.
PostPosted: Wed Mar 10, 2004 11:06 am
Anypix of you actual cable in progress. I am just major frustrated after buying assembling etc...
PostPosted: Wed Mar 10, 2004 5:14 pm
Ok
I am using the software off the mmcd site.
The schematics I posted are a simplified version. I have now constructed and tested both cables and both work.
The resistor I use is a 10k Ohm 1 Watt 5% carbon film resistor (i see the one youre using is 1/2 a watt)
The diode im using is a IN914 Signal diode
I will take a pic of my cable tonight when I get home.
Mike
1991 CB Lancer GSR (5dr Hatchback) with 4g61t conversion - 132kw/180hp @ the front wheels. SOLD!
Check out my website: www.members.optusnet.com.au/~onnzo
Member #31
PostPosted: Wed Mar 10, 2004 5:24 pm
Well im using it and it seems to work fine? and i know of at lest one other person who has been using it for months?
Mike
DUH! I assumed you were using that circuitry on a IBM PC style computer! :-? You're fully right, it WILL work perfectly on a palm! 8)
Got rabies?
PostPosted: Wed Mar 10, 2004 7:24 pm
I initially constructed the laptop cable as I didnt have a palm, but it was too bulky tot ake around teh laptop so i bought a palm.
So BOTH the Laptop and Palm cables work for me!
Member #31
PostPosted: Thu Mar 11, 2004 3:04 am
Hey Guys,
Here is a pic of my cable (this is the laptop cable) the palm cable is the same but one of the pins is changed.
Make sure you get the right pins!!!
Mike
Member #31
PostPosted: Thu Mar 11, 2004 8:58 pm
Well, mo fo...
I got my cable to work!! YEAH! My third try, I used a larger guage cable. Now it works. I also did my resistor and diode right to the pins like yours is. Now I just have to figure it out so I can tune my S-AFC II with it.
All this electronics crap may come in handy when I no longer just use it all as flashing lights, and over priced guages.
Thanks for your help Mike
PostPosted: Thu Mar 11, 2004 11:53 pm
No probs!
I cant believe people would actually pay $35+ usd for this!
It's so simple to make! (and thats coming from someone who hates dealing with electronics with a passion!)
Mike
Member #31
PostPosted: Fri Apr 09, 2004 7:26 pm
okim a bit confused(i took a little electronics in jr.high)what pins do i connect to and how do i make the other end?
1983 Honda VF750F
1986 Chevrolet C-10 305
1990 Chevrolet Corvette L98
1996 GMC Suburban 454
1999 Volvo S70 AWD L.P.T
PostPosted: Sat Apr 10, 2004 1:10 am
after re looking at it i figured out what pins and all, but how does the other end look?
1983 Honda VF750F
PostPosted: Sat Apr 10, 2004 4:11 am
http://www.fascinationsoftware.com/FS/h ... Cable.html
ok i think i see how it works, can someone verify findings? i/e if this one just plain old has alot of pointless electronics or is this one better
1983 Honda VF750F
PostPosted: Sat Apr 10, 2004 8:36 am
I took a brief look at it. It seems to be constructed straight ahead, w/ all eventualities in mind. While it is more complicated to construct than those other cables, it will be fail safe IMO.
Got rabies?
PostPosted: Sun Apr 11, 2004 10:02 am
The other end just has three wires which you crimp terminals on and plug into your diagnostic port.
As for which is better, I have no idea. I've made my cable, it was quick and easy, it works and i'm happy!
Mike
Member #31
