It is currently Thu Jun 06, 2024 11:11 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
PostPosted: Sat Nov 15, 2003 10:04 am
Installed a home-made breather filter yesterday inline w/ the PCV. It consists simply of a fuel filter for older/carbed cars, rigged up w/ some old fuel hose.
The results were remarkable. My idle is very stable now and the engine runs much smoother at idle speed. You can even see why when looking at the filter. It's full w/ oily crap after 190 km (about 120 miles) of high-speed driving at 4000+ revs. However, I can't tell how long this filter will last, as it is already rather clogged. Nonetheless, at 2-3 bucks a filter + some old hoses it's a bargain.
Got rabies?
PostPosted: Sat Nov 15, 2003 7:55 pm
I've got one rigged into the breather from rocker (by cam angle sensor) to intake pipe to catch some blowby. It also works well, but yes mine is rather full too. Mite be better to get oil catch can instead?.
AWD cyborg sedan
PostPosted: Sun Nov 16, 2003 6:15 am
Seems like those filters are merely a cheap diagnostic tool to find out if one's in need of a catch can. :D However, I never heard of THAT much blowby on the rocker cover breather. I had the filter there before I put it on the PVC line and there was never any oil in it. Maybe exessive blowby or clogged PCV?
Got rabies?
PostPosted: Sun Nov 30, 2003 1:02 pm
After 540+ km (335 miles) of driving, oil start to collect on the bottom of the breather filter. I think that's the maximum life span of such a thing, varying from car to car due to different wear (i.e. more or less blow-by). However, I already bought a new filter. It seems like my car starts and idles much better now with that filter. Except for their limited life time, thumbs up!
Got rabies?
PostPosted: Sun Nov 30, 2003 1:04 pm
What about trying to drill a drain valve into one of those filters?
PostPosted: Sun Nov 30, 2003 1:08 pm
A drain valve sounds promising. When I change the old filter, I'll try to clean it and construct some sort of catch can around it. I'll then post what results I get.
Got rabies?
PostPosted: Sat Dec 06, 2003 11:05 am
Heres an idea, How about using a AC Seperator? (Can't remember the real name but its the can with two lines and a pressure switch) Basically its a can with a tube going down to the bottom and a outlet to seperate vapor from liquid refrigerant. My thought is to drill and tap a drain in the bottom. It'll let vapors out but catch the liquid. Junkyards throw these out all the time.
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Sat Dec 06, 2003 12:20 pm
Sounds promising. Have you tried it aleready? Do you have a picture of such a thing? Never seen it before.
Got rabies?
PostPosted: Sat Dec 06, 2003 6:14 pm
Accumulator is the name! Ha, i remembered! No i havent tried yet. Benn thinking more on it and im going to look for one at work that'll do the trick.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Sun Dec 07, 2003 10:16 am
Aren't those things used in fridges? If so, one could have a nice breather filter for some 5 bux or so.
Got rabies?
PostPosted: Tue Dec 30, 2003 3:16 pm
That old breather filter is in there for some 1000+ miles now and still has some oil collecting inside. Even though this filter is dirty, my idle is still rather good, compared to a non-installed filter. I may try to wash it out with gasoline.
As to now, I can only give this a "both thumbs up" rating - highly recommended, good availability, nice results and very low costs.
Got rabies?
PostPosted: Sat Feb 28, 2004 8:54 am
After changing the filter for the only-god-knows time, I decided to clean the old filter w/ gasoline. Well I can't really recommend it. It won't get all oily sludge out, just a small percentage. However, it is quite a bit of dirt taken away, and this filter looks like it is usable an second time. If you're a cheap ass not minding all that crap on your work bench, I'd do the clean up. If not, just buy a new filter.
Got rabies?
PostPosted: Sun Sep 12, 2004 8:58 pm
Can you just put a breather cap on the valve cover?
1987 Dodge colt premier 4 door g32bt running!!!! 3speed automatics suck!
PostPosted: Mon Sep 13, 2004 5:07 am
Sure you can. But AFAIK those are expensive.
Got rabies?
PostPosted: Mon Sep 13, 2004 5:34 am
so the purpose of the pcv valve is to let air out but not in right? and you guys are talking about putting a fuel filter ritght before it to make it work better. my question is there 2 vac lines comming off of the valve cover, but they both combine on top of the intake. an open element filter wouldnt mess up any vaccum applications would it?
