It is currently Wed May 08, 2024 1:48 am
PostPosted: Mon May 27, 2019 7:59 pm
$8000 obo or if I win the lottery and I give it away lol jk
As much as I don't want to sell it the time has come. It's been setting for way to long and I want someone who could use the parts or the whole car before it rusts away.
Runs perfect but needs a starter relay (I started bypassing it a few years ago to turn to over). I start it up once every 2 to 3 months and let it warm up and I clean it. I add gas every so often to the tank is fairly clean and rust free. Hasn't been registered since September 2010. Tags are expired and I didnt put it on nonop like a dummy. I have came to this crossroad after the gardener last week broke the 1/4 glass weed whacking the back yard. Roof has rust spots popping up like mud volcanoes.
4G63t 1G built with eagle rods and mahle 2g pistons. Metal headgasket with ARP headstuds. Crower valve springs and retainers. HKS272 cams. Mild head port. RC engineering bored throttle body. Stock intake. 2G exhaust manifold with external tial 38mm wastegate. ACL race bearings. Balanceshaft eliminater kit with Mitsubishi stub for the oil pump. Oil pump was new when rebuilt. Has about 8k miles since rebuild. 60-1 ptrim in a bullseye exhaust housing. Chipped ECU with 1000cc injectors. MAF blow thru with Corvette AFM and maf translator. 255 walbro intank fuel pump. Aeromotive FPR. ACTsteet disc with 2600lbs pressure plate. WM31 transmission with shaft changed to match 3.5 rear. Short geared. White faced GS gauge cluster. 3 bolt rear. 5 lug eclipse steelies all the way around. Car isnt drivable due to the bad tires.
Tags expired interior partially stripped but has all the seats. I used to take the kids to school in it and drive it to work daily intill I couldnt get it smogged and lost my job back in 2010. I parked it and recovered but lost interest in finishing the car like I wanted to. Local preferred. Car is to be sold as parts only due to the tags and smog BUUUT you can do whatever you want. Car runs and drove great. Just tags and smog for California. Or you take it out of state and have fun. California title in hand.
Requests for pictures Leonardwhite.jr.lw@gmail.com
This is a sad day for me and I'm probably going to regret it later but better get it before I change my mind. I'm giving you guys first dibs before I post it on craigslist.
