It is currently Sun Jun 16, 2024 9:56 am
PostPosted: Thu Mar 03, 2016 9:00 pm
Swapping my Expo over for some more grunt. I've found a RVR trans and T case and my stock 1.8 3.54 rear isn't going to work. Looking for a drop in differential preferably but willing to swap the ring and pinion if anyone has a set they have changed over.
Thanks
PostPosted: Tue Mar 15, 2016 6:11 pm
I have a perfectly good rear diff from my awd auto 2.4 that i just swapped to a 5 speed. make offer, im sure shipping is going to be expensive though
PostPosted: Tue Mar 29, 2016 11:48 am
Still need this? I've got one in Baltimore, running car.
PostPosted: Tue Jan 31, 2017 2:19 pm
Still have this? I've got a swap on the way and only need the rear now.
PostPosted: Tue Jan 31, 2017 5:41 pm
I could supply 3.3 ring and pinion for rear end if someone needs one.
PostPosted: Tue Jan 31, 2017 7:37 pm
What would you want for it shipped to 24477? Also the one in the van now whines pretty good, not sure I should go that route?
PostPosted: Tue Jan 31, 2017 11:15 pm
165.
more likely work gears than a bearing. because worn bearings dont wine but gears do
PostPosted: Tue Feb 07, 2017 1:17 am
Found!
