It is currently Fri Mar 29, 2024 6:05 am
 Post subject: WTB: COLT VISTA LSD
PostPosted: Thu Jan 19, 2017 7:06 pm
I'm looking for the LSD/chunk with gears from an early (84-89) AWD COLT VISTA. I figure someone will run across one sooner or later in the yards... Anyone have a parts car laying around? Thanks
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
 Post subject: Re: WTB: COLT VISTA LSD
PostPosted: Thu Jan 19, 2017 8:57 pm
Gosh I don't even know if they exist....
PostPosted: Thu Jan 19, 2017 10:57 pm
Front, transfer case or rear end LSD?
If the Vista shares the same AWD/FWD setup that I delved I to when I opened up my F5M31 and F5M33, then you need an AWD Quaife diff (if you are doing the front), with the 25 spline center; AWD model fits all front diffs in that era/torque capacity of trans, and uses ball and cage bearings, extra shims on the lower ball and cage pressed in sandwich form and a speedo gear. I know this is the expensive route, but lifetime warranty! Maybe the diff is different? Maybe you don't want a front? What's it for ? Wink wink
PostPosted: Fri Jan 20, 2017 7:40 am
The rear one. Lots easier to remove :) it's possibly a fit in my 72 colt.
I know they exist. I've seen them. Just didn't know the spline count on them is supposedly the same as the same on my rwd colt....
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Mon Feb 20, 2017 7:32 pm
Anyone near this?
https://medford.craigslist.org/cto/6002825873.html
I'll buy the rear diff and you can scrap the rest :D
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Feb 22, 2017 10:57 am
I am quite certain that all of the vans sold in the US were open rear diffs.
1985 Mitsubishi Cordia
Build in progress
PostPosted: Wed Feb 22, 2017 5:54 pm
I'm not so sure about the early ones, but its easy as looking on the diff to see.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Feb 22, 2017 11:50 pm
I'm sorry I just realized you said an 89 vista.
I was thinking the 92-95 expo vistas most people have.
I know nothing about the older ones. So are they a solid axle and that's why it may fit your old school colt?
PostPosted: Tue Aug 27, 2019 11:10 pm
Bump.. still looking
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sat Feb 08, 2020 10:46 am
BUMP: Still looking guys!
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
