It is currently Sun Jun 16, 2024 10:17 pm
 Post subject: 4G63T Evo1 RS in a C53A
PostPosted: Tue Nov 10, 2015 11:36 am
Since the previous owner did a bad job fitting this motor to the chassis.. now i have to figure it how to get it fix..
the hole for mount the gearbox at the chassis left side is totally ripped.. and the radiator support is splitting 2..
back to drawing table.... :(
PostPosted: Tue Nov 10, 2015 11:43 am
akubullet, could you please put a location in your profile. Part of the rules at signup.
7 bolt motor and matching transmission setup?
What code is on the top of your bell housing?
Pic of the front of the block where the mounts attach? Pic of the damaged holes at for the transmission mounts and frame area?
I can't see the bottom two pics. I looked at the picture links code for your last two pictures and they don't contain links to pictures; IE .jpg .gif etc
PostPosted: Tue Nov 10, 2015 2:22 pm
You mean the hole in the transmission for the mount? Drill/tap to the next largest size.
PostPosted: Thu Nov 12, 2015 8:51 am
my bellhousing is
W5M332 WQWE - QQ5919
stock lancer evolution 1 (RS) transmission.. currently im busy clearing the engine bay for a new set up
https://picasaweb.google.com/1126436557 ... 169/MIRAGE
PostPosted: Thu Nov 12, 2015 2:50 pm
https://picasaweb.google.com/1126436557 ... 4607715522
bellhousing code is W5M332 WQWE
https://picasaweb.google.com/1126436557 ... 2427399682
PostPosted: Sun Dec 06, 2015 10:06 am
akubullet, your project looks sound once you get that radiator support fixed. Truly sad to see it broken that badly.
You can get new radiator support parts from the US, but their dollar is strong right now, and shipping is expensive.
I don't suggest a repair of the original part, as you likely need to straighten the frame rails or at least have them checked for.
Does the hood close and maintain a few MM's gap on both sides of the hood to the fenders? If this gap is larger on one side and the hood is aligned (also properly closes on the hood latch!), then your rails may be okay. I would have the rails checked and pulled straight before putting any rad support back in. Please consider this! Otherwise you will weld in new frame rails with a new radiator support and have a bent/tweaked front end.
I can see that if you also knew some people who are good at welding, you could design your own front radiator support, but it's better to buy the correct part. There is the option to get one from a dismantler/parts company in Malaysia. There are companies all over in Malaysia that part out GVR4's and likely C50 style cars if they can find them.
Keep posting, as we want to see this car transform and get road worthy.
