It is currently Sun Apr 28, 2024 4:52 am
PostPosted: Sat Oct 24, 2015 11:01 am
Wondering if anyone else has this combination of parts in their car.
I have a GVR4 aluminum radiator on the way. Have a 1G 4g63t setup in the car, including a 1G water pipe that sits very close to the scatter shield.
The GVR4 upper hose position is offset to the right by an inch or two, of where the stock Colt/Mirage turbo hose is located.
Lower hose seems to be in the same spot.
Anyone have part numbers or pics of hoses that they used to make this or a similar combination work?
Not having a wall of hoses at the local parts stores, is running thin right now.
PostPosted: Tue Oct 27, 2015 10:31 pm
I had a gvr radiator in my car at one point, I think I 1g hoses or gvr4 ones.
PostPosted: Wed Oct 28, 2015 6:40 pm
I currently have a complete 1g setup aluminum mishimoto rad, ebay Silicon hoses, and thermostat outlet. Its maybe an inch shorter in height compared to stock.Might be able to use the 2g top hose to get the gvr4 right
PostPosted: Fri Dec 11, 2015 7:30 am
I have a gvr4 radiator on mine, top hose is from galant but I had to trim it to fit, bottom one is from elantra 1.8L
PostPosted: Fri Dec 11, 2015 12:41 pm
Thanks guys!
I got a Galant lower (VR4 variant shouldn't matter) as they should all be the same with the 4g6x motor listing in that chassis.
Not sure what I have up top, but it may get re-used. DSM or Galant seems to be a consensus for top hoses. I may vary well have a DSM upper currently, trimmed to fit.
Users browsing this forum: No registered users and 59 guests
