It is currently Sun Apr 28, 2024 9:58 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Mon Jun 15, 2015 2:49 am
Hi. Ecu is e39a vr4 and same as the maf. Td04L turbo and evo 510 injectors. I dont think we changed the coolant temp sensor off the 4g61t so ill try that! Thankyou
PostPosted: Mon Jun 15, 2015 2:54 am
Hi. Car is running a E39a vr4 maf,ecu and turbo. Evo 510 injectors.iinjectors.i dont think we changed coolant temp sensor off blown 4g61t so im hoping this is my issue. Thankyou
PostPosted: Mon Jun 15, 2015 9:25 am
The temp sensors aren't different between turbo and non-turbo, but yours could be acting up. The E39A VR4 ECU and MAF aren't calibrated for the 510cc injectors, so that could be causing an issue as well. These cars had 450cc injectors. That would cause you to run a bit rich at idle and partial throttle. I'd recommend getting a S'AFC or something to tune out the difference in injector size.
PostPosted: Mon Jun 15, 2015 3:14 pm
Tony, didn't some GVR4's come with larger injectors and a 16g? I know the ones we got here in the states didn't but I'm pretty sure some did in other parts of the world.
PostPosted: Mon Jun 15, 2015 3:23 pm
Yes, if he has a GVR4 RS setup then it would come with the 510's and everything...those are kind of rare though, even overseas.
