It is currently Mon Apr 29, 2024 8:22 am
 Post subject: FWD ecu in an AWD
PostPosted: Sun May 03, 2015 11:51 am
so......
any thoughts?
do you think the shift points are different?
I assume everything else should work
 Post subject: Re: FWD ecu in an AWD
PostPosted: Sun May 03, 2015 11:57 am
what do you mean shift points? if its auto then there is a totally diff tcu that controls the shifting.. if its a manual then there are no shift points...
but to answer your question we would need more info like what kinda car.. year..engine size..stock or swapped.. I dont think there is much of a diff between fwd and awd ecu's but if there is its something small like inj size.
a description of the problem you are having (if any) would also help.. or are you just trying to use what you have to get a car running?
PostPosted: Sun May 03, 2015 12:07 pm
sorry....
just playing games with my son.
I have a 93 AWD Auto vista wagon
looking at purchasing a 92 FWD Auto summit
I might want to keep the 92 ECU for future use...... although, it occurs to me as I type that the 92 should have an 8 valve SOHC while my 93 is the 16 valve 2.4.
Your probably right on the injector sizing...... i'll have to check that out.
PostPosted: Sun May 03, 2015 10:56 pm
It's a pretty common thing for auto DSM guys to use manual transmission ECU's as an upgrade. As slowdsm said, there's a seperate computer for the transmission. Yes, injector sizing is different between auto and manual cars, at least on DSM's...no clue on the minivans, but probably not too different.
