It is currently Sat May 04, 2024 4:10 pm
Post new topic  Reply to topic  [ 53 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Wed Apr 15, 2015 12:52 am
I just had a huge update and got an sql error when I went to send it -_- tomorrow I'll try posting it again from my laptop.
PostPosted: Wed Apr 15, 2015 11:21 pm
Mods
Motor:
Stock bottom end 7 bolt 1994 (1g)
New front case with Balance deleted
I switched the case to 1990 straight cut gears
Arp head studs
Cometic MLS head gasket
Head:
2g Head
comp state 3 cams
Dual valve springs and titanium retainers
3g lifters
Trans:
IPT shift kit
IPT end clutch kit
Kigly front clutch basket
Forced four shift box
Arp flex plate bolts
stock converter :/
Turbo:
Hx35 with fresh rebuild from justin
-12 an drain welded to oil pan
-4an feed from ofh
Oil pressure gauge to check to see if i will need a restrictor
Bep .55ar mitsubishi bolt on housing
SBR Manifold with 2 bolt wastegate
Custom 3" v-band o2
Side exit
2g VRSF Intercooler
Tial Bov
Brakes:
1g Big brakes
3g master cylinder
brakes are all braided stainless steel line
Fuel:
Bosch 1600cc injectors
10 gallon fuel cell
-6 an line feed/return
Bosch 044 pump
Aeromotive AFPR
Fuelab fuel filter
+ pre fuel pump filter
Electronics:
Evo 8 Ecu
LC-1
Mac electronic boost solenoid
LS1 Coil pack
7" touchscreen gauge cluster
7" touchscreen double din carputer
Tube frame here I come!
mmmmm dem welds! not bad for only my first 20lb bottle of gas :P
Mock up motor is in!
Built an ls1 coil pack for the car.. will test it out after the cars running. got it for free.. so dont flame :P
Bunch of goodies came!
Got the head torque down and turbo all mocked up
Send the turbo out for rebuild early this week should get it back next week..
Started mocking up the fmic... had to cut out practically the entire bumper :P
Mounts for front mount and radiator are done
Theres it with the bumper on
Rear is completely in!!
Have the fuel cell in for mocking up lines.. going to build a sheet metal firewall around it.
Ive been working on the harness latley..
Completely rebuilding it
Starting to mock it up on the car.
Im sure I missed a few pics :/
Heres an idea of what i will be doing with the dash.
The dash is all cracked on mine so i will be fiberglassing it and molding in a few of my touch screens
For data logging/gauges
PostPosted: Thu Apr 16, 2015 6:26 am
Wow, what an update. Looks great so far!
PostPosted: Thu Apr 16, 2015 11:22 am
Haha yes it was I kinda forgot that I hadn't been updating this... after a 10 hour day working out in my garage i'm normally to tired to mess around posting.. :P
Automotion car show in the wisconsin dells is 30 days away.. I plan on having the car completely done by then.
Whats holding me up right now is finding a valve body separator plate.. Dealer is discontinued and no one seems to have a new one.
PostPosted: Thu Apr 16, 2015 11:29 am
I really need to paint the intercooler black... Sleeper effect kinda went out the door when i decided on that gigantic intercooler lol
PostPosted: Thu Apr 16, 2015 1:41 pm
That escalated quickly!
How do I vote?
92 Colt GT 4G63t
92 Summit TSI AWD 4G63t Auto
5 X 90 Talon TSI
90 GSX
PostPosted: Thu Apr 16, 2015 5:09 pm
No longer voting :P builds set.
Ran out of money so i wasnt able to build the motor
And i went auto because it was going to be cheaper/more reliable
PostPosted: Sat Apr 25, 2015 12:34 am
I'm really starting to loose motivation.......
Probably because i haven't really been able to work on it for the past week.
Waiting on a valve body separator plate from the dealer...
Cant put the engine/trans back in until i have the plate and can do the ipt shift kit
PostPosted: Fri May 01, 2015 9:16 pm
Some really nice inginuity in this... I have a 7" touchscreen sitting around and you gave me some motivation to put it in the dash with a carpc setup...
What are you using for a PC? where did you mount it? trying to get some ideas flowing for my own...
PostPosted: Sat May 02, 2015 12:39 pm
It's a mini pc and I can put it inside the gauge clusters
I build and sell gauge clusters/double dins if your interested it's around $300 for a full pc
PostPosted: Sat May 02, 2015 12:44 pm
Got the engine harness done.. All tucked and sleeved
Looks pretty damn good in my opinion...
Here's what it's like going into the firewall/back of engine
Don't mind the motor mount I just had to tack it in place so I could weld in the mount when the motor is out
Which will probably be done Monday then I will paint the bay and it will be ready for final assembly
Today I'm doing wiring and making the mounts for my drive shaft
PostPosted: Sat May 02, 2015 6:24 pm
I hate making decisions on wheels/tires
PostPosted: Fri May 08, 2015 10:41 am
Im un decided on my hx35 weather i want to run it or not.. Kind of want to sell it and make a hybrid 20g
Billet wheel extended tip compressor wheel
3" compressor housing from turbo lab
tdo5 shaft on a tiny 6cm exhaust housing
And have the thing spool like crazy but still make almost 400hp
Im very indecisive on what route to go.. as you can see in this tread alone ive changed my mind 20 times. lol
I have to keep reminding my self i rather autocross the car than drag race it...
At this point i might even convert it back into a street car/daily driver
And put all the interior back in.. not really sure what route i want to go.
Either way heres an update with pics
I painted the bay after pulling the motor for the millionth time :P
On the bright side ive gotten pretty good and pulling the motor/trans in and out. got it down to a science now.
Heres where i had my drive shaft shortened guy did a great job $100 and life time warranty
Finished up the side exit exhaust
Time to re-angle the strut towers i knew it was going to suck.. but inevitably needed to be done i did not want to mess around with spacers/adapters
One side down one to go..
Need to do the last 2 drive shaft mounts yet and finish up the wiring and the car will be done.
Going to pick up some evo 8 seats tomorrow!
PostPosted: Fri May 08, 2015 8:06 pm
Very nice!
PostPosted: Sun May 10, 2015 6:16 pm
UPDATE!!
Sold my hx35 for $450
bought some evo recaro seats and ordered some 5 point cam lock harnesses from summit
And I got the trans cleaned up some filled the converter and put the trans on!
Running dual flexplates with arp bolts.
Waiting on getting a shipment from Buschur for the flexplate/torque converter bolts locker
waiting on till I finish my car to decide on what turbo to run
Till then going to rock my 14b :supz:
Trying to decide on whether to go with like a small 16g or a hybrid td05 20g
i want to autocross the car so the s16g would be perfect but i would also like a decently powerful car ugh the struggle is real
Tentative goal is to have my car done by friday... so I can take it to automotion in the wisconsin dells. as long as nothing stupid comes up and i cant get parts in time it should be a go!
