Got into it with the lathe today ...
I mean, I figured out that just because the tire machine doesn't have a constant spin function, doesn't mean I can't spin my wheels ... so to speak.
I've been stripping and restoring these rims for the nearly a year or so.
They started out silver, then were painted black, completely black.
They spent lots of life on salted roads, got corrosion on the bead lock area and green slime in the one that I suppose would not hold air.
Price was right and they are pretty straight.
All four center caps present and ready for duty sir!
Moving forward to today and I got them on the brake lathe to speed up the lip polishing and bead lock surface restoration process.
IE, hold sandpaper in various grits, to the metal surface. Finally ended with wet sanding on the polished outer lip for each rim.
There is some spot filler putty in the one rim on the spoke sections and some minor bobos here and there, and if it were not for the red bondo,
I would likely be rocking the raw aluminum finish and a polished lip ... if not also because of the plastic (grey) center caps, not looking like raw aluminum.
PICS!!!!
Starting point:
Glass bead 40-80 or 80-120 grit? Free dings, get yer dings .... and don't use Walnut for this process. Just saying ...
I have a lot of work ahead of me.
8 months later, and 2 blast cabinets later, I return for more punishment.
Mounted.
40 grit on the back side.
Getting there .....
Dry 180 emery cloth, 240,
Wet 400, 600, 1000, 1500, 2000
Mother's Mag and Aluminum Polish in a small white plastic oinment container. Looks like the stuff you put on poison ivy. Memories .....
Better.
