It is currently Wed Jun 05, 2024 5:10 am
Post new topic  Reply to topic  [ 31 posts ]  Go to page 1 2 3 Next
PostPosted: Mon Feb 02, 2015 6:00 pm
So to keep me sane with this winter I am posting a turbo picture a day till I run out. Here is a picture of a 80 Corolla I put a g54 ( I think this is correct) from a Starion with a Garrett turbo, Megasquirt
PostPosted: Mon Feb 02, 2015 11:12 pm
Nice! Looking forward to this thread.
PostPosted: Tue Feb 03, 2015 8:13 am
Today is a double pic day. 1st, another shot of the Corolla
Next is a picture I call "how did I do this"
PostPosted: Wed Feb 04, 2015 7:31 am
Well, no one interested on how I broke the output shaft from a Starion transmission.
Here is the today's pic
PostPosted: Wed Feb 04, 2015 7:54 pm
the white stuff on the exhaust manifold is from a fire extinguisher, had a small problem when tuning. i only took the car to the track 2 times. The 1st time was when I finished it and made 5 runs. Started at 12.4 and finished witha vehicle best of 11.4@121. I was having issues with the drag radials hooking up so the next week end I borrowed some wrinkles and went to Epping. Heated them babies up and staged. I went to about 5 grand, dumped the clutch and the front end lifted up. Then BANG, towed back to truck and found the output shaft broken in 3 pieces. Turns out it launched, suspension squatted and the sticky tires stuck to the tops of the fenderwells.
Solid motor mounts, no interior, no heat, and as it turns out no fun to drive unless you are at the track soooo down the road it went.
On to the next
PostPosted: Thu Feb 05, 2015 2:07 am
Great story and pics! Keep'em coming. :)
PostPosted: Thu Feb 05, 2015 10:08 pm
Looks like another double picture day!!
So I bought a top mount DSM manifold on Ebay and refabricated the mating flange so I could put my new Turbonetics t3/t4 on a ......
PostPosted: Sat Feb 07, 2015 9:02 am
Manifold installed
PostPosted: Sat Feb 07, 2015 9:38 am
I love this thread! It's eye candy for the common man. Thumbs up. !!!
PostPosted: Sat Feb 07, 2015 9:00 pm
So Here is what it looked like on
and here is what it looked like with the bigger turbo installed
PostPosted: Sun Feb 08, 2015 8:27 pm
Made the down pipe
I LOVE WELDING!!!!!!!!!
PostPosted: Sun Feb 08, 2015 11:16 pm
Some wrap and custom heat shields should keep the timing covers from melting. ;)
ImALikEThiSbUilD.
PostPosted: Mon Feb 09, 2015 9:34 pm
So I finished upgrading the turbo on the 84 escort,click link below to see the 1st turbo set up
http://www.4g61t.org/forum/viewtopic.php?f=42&t=39858
With my custom divorced header
And......................................
PostPosted: Tue Feb 10, 2015 8:40 pm
Decided to take it for a ride. Using a LA3 ecm from a Turbo coupe and and posative gain fuel pressure regulator with a Walbro. I wanted to see what a good turbo would do. I had pushed the IHI RB20 to 16lbs and then tried 22lbs but it was way out of it's compressor range. It really went the same with 6lbs more boost. On the street I went with the new setup and was ready for the fun to begin. Easy in 1st gear then hit second and floored it. Boost begins to build and boy does it feel much better than the crappy IHI. 10-16lbs-wow then I see 24lbs and man does it feel good then I hear a noise and quickly look at my wideband.... All I see is lean, in the rear mirror ....smoke, No good. Limp it back to the shop and see the carnage. I broke all 4 pistons,destroyed the head and found out the importance of keeping the fuel in par with the boost or more accuratly oxygen. 24 lbs of boost on a efficient turbo is way different than the same boost on crappy, too small turbo.
So........
PostPosted: Tue Feb 10, 2015 10:11 pm
.... teh start of paperweight thread is beginning! ;)
Sorry to hear about the motor coming apart.
