It is currently Tue Jun 04, 2024 7:33 am
Post new topic  Reply to topic  [ 61 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: f5m21 trans exploded
PostPosted: Thu Dec 04, 2014 8:18 pm
Anybody have a good f5m21 trans for sale or an idea what other trans i can use behind my 1.5? i just purchased a new clutch kit and flywheel and would like to be able to use them on the new trans.
 Post subject: Re: f5m21 trans exploded
PostPosted: Thu Dec 04, 2014 10:23 pm
Is yours cable clutch or hydraulic?
PostPosted: Fri Dec 05, 2014 7:17 am
If you are hydraulic, then the f5m31 will work. Using one now on a 1.5
PostPosted: Fri Dec 05, 2014 9:48 am
Yes the trans is hydraulic. Anybody have one for sale?
PostPosted: Fri Dec 05, 2014 11:13 am
What did the f5m31 trans go in?
PostPosted: Fri Dec 05, 2014 2:35 pm
1.8l equipped Talon/Eclipse/Laser (1990-94) and 88-92 Galant are some that come to mind.
PostPosted: Fri Dec 05, 2014 3:35 pm
So my clutch and axles would work with it?
PostPosted: Fri Dec 05, 2014 5:13 pm
The na 1g dsm's used the F5M22. The CSM axles won't work since the stubs are shorter. I thought the F5M31 came in the 94-98 Galants and the fwd summit/expo/colt vista.
PostPosted: Fri Dec 05, 2014 5:54 pm
I really need to figure this out before I drop money on a trans I'm.stuck with. Another F5M21 would be great if anybody had one for sale. Its just a work car I need to get back on the road.
PostPosted: Fri Dec 05, 2014 6:40 pm
Well, the answer is yes, you stock stuff will work
PostPosted: Fri Dec 05, 2014 6:46 pm
Im confused. 89Mirageman says that the axles wont work. So the F5M31 trans is the way to go?
PostPosted: Fri Dec 05, 2014 6:54 pm
It looks like the slave cylinder on the F5M31 trans has a rod that pushes the fork. My F5M21trans has a little bracket on the end and a pin goes through it with a clip to the slave cylinder.
PostPosted: Fri Dec 05, 2014 8:58 pm
My colt had already come converted to the f5m31. I assume you would need a slave from a 1g eclipse unless the clutch forks are interchangeable?
PostPosted: Sat Dec 06, 2014 12:29 am
All I know is that the inner axle stubs that snap into the diff on the transmission are longer on a 1g dsm than they are on a 1.5 3g csm. The diameter and spline count are the same between both but I don't think the 1.5 axles will snap into the diff like they should. Maybe I'm missing something here. If Thom says he's running the same setup I don't doubt his word. I just don't see how the axles are staying in. Maybe there's something I'm overlooking.
PostPosted: Sat Dec 06, 2014 8:44 am
Couldn't I just get axles for that F5m31 trans and use the inner joints on my axles?
