It is currently Sun Apr 28, 2024 10:29 pm
PostPosted: Tue Sep 23, 2014 7:55 pm
Hi,
I'm looking to replace my old OEM panhard with something more "ajustable".
Does someone know if a mustang (05-14) panhard bar fits ? Does it need to be cut (reduce the length) ?
Any comments, brand, model, review is welcome !
Summit Rcaing Panhard bar : http://www.summitracing.com/int/parts/s ... /overview/
Dodge Colt 1992 4G63T -= Racing Car =-
Toyota Corolla S 2015 -= Daily Car =-
Mitsubishi Outlander V6 2009 -= Family Car =-
PostPosted: Wed Sep 24, 2014 6:34 am
Find out the diameter of the bolt sleeve they insert on either end of that part.
Next, you need to know the length from bolt hole to bolt hole, minimum setting and maximum.
This way you know if you have the range needed (well the minimum length with some adjustment) to be able to use the bar.
If the site does not mention these specifications, you will have to call, or do some IntarWeb searching on ..... dare I say it ..... Mustang Forums! :rock:
PostPosted: Wed Sep 24, 2014 8:08 am
I'm very interested to see where this thread goes.
PostPosted: Sat Sep 27, 2014 6:58 pm
I was using, until recently, an adjustable 1G panhard. It broke the other day on one of the ends, perhaps because it wasn't the right length (maybe too long or short, no idea?). Anyways, I didn't find any adjustable replacement online and even finding a new one was difficult. After not being able to get a new one from all the major part stores in town and the Mitsu dealer also not having them available, I found a new one on http://www.discountmitsubishiparts.com for 60 bucks. A cheap adjustable one would be nice, though.
89 Colt GT Turbo - Durham, NC
PostPosted: Sun Sep 28, 2014 9:00 am
If you don't mind a little more noise, you could get a swedged tube and rod ends from speedways motors for less than above.
PostPosted: Mon Sep 29, 2014 7:25 pm
Does anyone happen to know the length of the stock bar?
PostPosted: Sun Oct 26, 2014 8:07 pm
Here is the length :
DSM 1G FWD : center hole to center hole = 42 inch
CSM (89-92) : center hole to center hole = 42 3/4 inch
I did a search, but did not find the length of the mustang pan bar. Can anyone help me to find the length ?
PostPosted: Sun Oct 26, 2014 9:13 pm
You would have to ask someone with a Mustang, like on the forums for 05-14 models.
I searched and could not come up with a difinitive answer, sorry.
Most guys only need to know it's the correct part, and how to adjust it once it is in place.
You have to make sure the end pieces are the correct width to fit the CSM braces they bolt into.
PostPosted: Sun Oct 26, 2014 10:15 pm
contact there guys..and either buy the parts and make 1 urself.. or have them make one for you..
http://www.rodendsupply.com/
PostPosted: Sat Jan 31, 2015 9:25 am
Well, last night I try another time to find the length.
here is the answer of Steeda (panhard bar for mustang) :
Hi Guillaume,
There is about 3 inches of range of adjustment on the panhard bar.
So you could figure it would be at least 1.5 longer or shorter than stock.
Thank You,
Rod Williamson
Sales Associate
Extension 1117---
Steeda Autosports, Inc
http://www.steeda.com
1-800-950-0774
PostPosted: Sun Apr 19, 2015 7:40 pm
On amazon, most of ajustable panhard bar for mustang are 46 inch.
http://www.amazon.com/Hotchkis-15102-Ad ... A5MFGECT7S
PostPosted: Tue Jun 28, 2016 11:56 am
Here's more of a universal option. https://www.summitracing.com/parts/cee- ... fgodKCcCyQ
Anyone have any luck finding an adjustable that bolts on?
Although I think it would be easy enough to cut and shorten the Mustang bar, if length is the only issue.
PostPosted: Wed Jul 13, 2016 9:32 am
I think cusco has one not sure though will double check on it
Users browsing this forum: No registered users and 65 guests
