Thanks everyone for the replies. Sorry it's been raining alot.(I have a garage for 2 1/2, but my trucks in there because apparently my village is anal if you dont have valid plates which I switched my veteran plates to the colt. The rest the garage is messy.)
Anyways, update..
Unplugged the CAS and resistor. Cranked and no fuel enters
![:)](./images/smilies/icon_smile.gif)
Good to know my 2nd injectors and fpr are good. No guel enters fpr vac line while.cranking
Plugged CAS and resistor and cranked, it flooded..So its eletrical.
I'm gonna try a different ecu and check all wiring. Hopefully tommorrow the rain finally goes away.
I have spark from wires and plugs. when cylinders are dry i crank and doesnt attempt to start.
I'm guessing so much fuel. So for 2nd time ill change oil and crank with resistor unplugged to circulate oil to build compression and try starting..
I hope to figure this flooding issue soon
