It is currently Thu May 23, 2024 12:07 am
Post new topic  Reply to topic  [ 108 posts ]  Go to page Previous 13 4 5 6 7 8 Next
 Post subject: Re: Little Bird
PostPosted: Sat Apr 19, 2014 3:20 am
Thom, if you could do a small writeup of the Saturn install, I'll add it to the tech archives. it's something I need to do after frying 3 alternators.
PostPosted: Mon Apr 21, 2014 7:04 am
Sure thing. Where do you want it at? In this thread or should I start a new one?
PostPosted: Mon Apr 21, 2014 2:44 pm
Start a new thread, then I'll move it over.
PostPosted: Tue Apr 22, 2014 9:06 am
Ok, I posted it in the 4g61/4g63 tech section.
PostPosted: Mon Jun 09, 2014 7:18 am
Just small updates.
Put on black wheels with better tires
Installed a detachable steering wheel hub for my NRG wheel to get it closer to me since I have my seat in the way-back position (I am 6’8”)
Installed a new Pioneer deck just because
Obtained a set of window vents from Poland that are actually designed for my car
Installed a new Tial Q BOV and a Hyundai VC
Yanked the Maf-T and installed the ECMLink MAF cable for the 3" GM-Maf
Next in line?? Tial Sport externally dumped WG on SBR manifold, subwoofer/amp combo and a separate amp to power the front separates. Then it will be time to build the Summit Wagon!!
PostPosted: Mon Jun 09, 2014 7:32 am
Looks great, I always like to see updates on this project. 6'-8" in a 3g hatch, I bet you get some weird looks. :o
PostPosted: Mon Jun 09, 2014 8:36 am
That I do. Part of the "WOW" factor with the colt. :lol:
PostPosted: Sat Jun 14, 2014 9:36 pm
Treating her well man, that's good to see. Let me know if you ever decide to sell! I'd love to have her back.
1991 Dodge Colt - 1.5L 4G15 - Swap Project
1989 Dodge Colt GT - 2.0 4G63T - Racecar
1995 Honda Prelude - H23A2 - DD
PostPosted: Mon Jun 16, 2014 6:42 am
I will, but this will be here for a long time. This winter she is getting the AWD treatment, I have a GVR4 rear subframe, rearend (4-bolt), awd tranny and vfer case just waiting for this winter's work.
PostPosted: Mon Jun 16, 2014 5:29 pm
Very nice build so far, just needs an FP manifold to really pretty up the bay. :wink:
PostPosted: Tue Jun 17, 2014 8:30 am
Nah, I have a SBP manifold with Ext. WG flange (and a nice polished heat shield) laying in wait for my lazy butt to install.
But, had a major success last night (I hate rattles immensely). Been searching since November for a rattle in the Colt drivers door. It sounded like it has ball bearings loose everywhere in it. It rattled so bad when shutting the door and while driving that it was embarrassing. I tightened every thing down, adjusted the door striker, all to no avail. Yesterday I decided to try again and I finally found the issue. The crash beam in the door no longer has the expanding glue between it and the outer skin (Same thing that happens to the hood causing it to sag so much when supported by only one prop rod). It is hard to get in there with silicone sealant so I used expanding foam sealant for home windows and cracks. Let it set overnight and now the door is as solid sounding as a colt door can be!!
PostPosted: Thu Jun 19, 2014 7:58 pm
I spent weeks looking for those rattles! Haha, glad you found them. I threw some dynamat in the doors hoping it would help, but sounds like you got it done.
PostPosted: Fri Jun 20, 2014 5:23 am
I jammed a piece of cardboard in mine iirc. :lol:
PostPosted: Fri Jun 20, 2014 6:49 am
Yea, it was a real mystery for a while. Couldn't figure out why the pqssenger door shut like a vault and the drivers door sounded like a school book locker. Much happier now. Still have a tiny rattle, but that is because the plastic on the door striker is worn. I will swap it our with the passenger side since that side is rarely used.
PostPosted: Fri Jun 20, 2014 6:53 am
That would have been much easier. Too late now!! :)
