It is currently Wed May 22, 2024 12:56 am
PostPosted: Wed Apr 02, 2014 10:46 am
Im looking for an ECU pinout picture, info on swapping a 6 bolt in, electrical diagrams etc. I will be looking in Evolution 123 and tuners, just posting on here in case any of the gurus have dealt with this before and have some info. If you do please let me know thanks
Heres how she sits as of now. Still have plenty of components to throw on but the donor engine is in need of a new head due to an overheat
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
PostPosted: Wed Apr 02, 2014 11:13 am
http://www.lilevo.com/mirage/ECU%20edit ... INOUTS.pdf
PostPosted: Wed Apr 02, 2014 3:26 pm
Sweet car!
PostPosted: Wed Apr 02, 2014 3:51 pm
Thank you both of you. She still needs the engine installed, wires tucked and a good paint job but it will do for now
PostPosted: Tue Apr 08, 2014 6:36 pm
It doesn't need another paint job, it needs brakes!
You have coilovers and now an uprated engine, but unless I'm mistaken, still using the factory stock 93+ vented rotors?
PostPosted: Tue Apr 08, 2014 9:31 pm
No still shit engine haha. The 91s engine is far worse than I had imagined and needs a full rebuild so the Evo is on the back burner for now. What brakes would you suggest in the rear? It's 4x100 lugs up front but I could probably press in 4x114 or 5x114 honestly but the rear is drum
PostPosted: Wed Apr 09, 2014 6:53 am
I make a rear disc kit for the 4g and 5g Mirage. It also allows you to stay 4x100. You can also bolt on early diamante or 2g awd dsm twin piston calipers and 276mm 4x100 Mini Cooper S rotors on the front, they fit right over the existing hubs. Or if you want something even larger up front I have an adapter that allows you to run later model diamante calipers and 314mm Mini Cooper Turbo front rotors. You'll need a 17" wheel to clear these. A 3g Eclipse 1-1/16" bore M/C will fit too.
PostPosted: Wed Apr 09, 2014 8:31 pm
Damn and those brakes are cheap as hell too, thanks. Ill send you a PM for the rears... and as always thanks for all the info it helps a ton
