It is currently Thu May 16, 2024 1:43 pm
 Post subject: Weber carb install
PostPosted: Thu Mar 06, 2014 6:29 am
I'm putting a weber 32/36 carb on my 78 arrow 2.0? Any pics-routing of hoses- I AMA bit perplexed? I don't want any-any emissions stuff hooked up if I can! Dean
 Post subject: Re: Weber carb install
PostPosted: Thu Mar 06, 2014 11:07 am
Anything that era will need a factory service manual, paper version.
Our online manuals don't go that far back.
If you hooking things up on a 78, there can't be many vacuum hoses to worry about.
Vacuum/distributor advance from the carb base to the nipple on the distributor.
Vacuum hoses from the carb base to the firewall for dash vacuum control (if equipped that way)
Might be a vacuum hose from an exhaust heater pipe/diaphragm up to a wax pellet sensor (two nipple), and that take vacuum from the carb base.
These were all the most common setups back then, but it depends on how Mikuni/Weber set up their carbs/bases.
Do you have the original carburetor and related equipment?
PostPosted: Thu Mar 06, 2014 11:58 am
Yes I do. It is mostly I'm crap attached to the carb. I guess I was a bit nieve in thinking I actually needed to hook up some, or most, of the lines when in reality only vac advance and a egr is necessary. I went online to weber carbs direct and downloaded a manual to set up my webby for a mitsubishi engine? I'll ask more advice as needed and really can't wait to get it back to driving again. I had runnin hella good w/ the bs hooked up! Thanks. I say let's put a dodge 273 or 318 in the little prick!!!vroom vroom my ass! Beep beep...
PostPosted: Thu Mar 06, 2014 12:07 pm
You might want to check out
http://classiccolt.forumcircle.com as well. :)
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Thu Mar 06, 2014 3:57 pm
Good call natedog!
