It is currently Tue Jun 04, 2024 4:40 am
Post new topic  Reply to topic  [ 93 posts ]  Go to page Previous 1 2 3 4 57 Next
 Post subject: Re: 4 years later
PostPosted: Sun Mar 02, 2014 9:41 am
Like a tank. In a good way.
Worried about the tires hitting, especially as the rear shunts over to one side during compression ... the issue with lowered panhard setups.
Adjustable panhard rod will help for sure. Anything lower than 1.5" should be using one, as a rule of thumb here.
What rim sizing offset, center bore diameter and tires sizes are you running ??
PostPosted: Sun Mar 02, 2014 10:58 am
Looks beefy man, are they sticking out further in the front?
PostPosted: Sun Mar 02, 2014 12:15 pm
I would guess 15x8 +20. Maybe a 16". Those wheels only come in a +20 offset as far as I know. The front probably sticks out a little more too. Common problem on CSMs that is usually only more noticeable with an aggressive offset wheel.
PostPosted: Sun Mar 02, 2014 2:06 pm
They are 16x8 +20 225/45s
PostPosted: Mon Mar 03, 2014 5:40 pm
it dose sticks out a lil bit more in the front but i can pull the front fenders easy i think the rear is going to be a lil bit harder to pull.i would also like to get a set of coilovers or a set of stiffer struts and springs because right now the rear is super soft. the wheels are 16x8+20 with a 225 45 bridgestone G-force tires.
08 silverado max
91 Eagle Summit 4g63t swapped
PostPosted: Fri Mar 07, 2014 2:13 am
well i did a lil work on the car today i pulled the fenders
before
after
after that i installed the battery setup.
08 silverado max
PostPosted: Sun Mar 09, 2014 11:22 pm
messed around a lil bit today in the gaurge did not do much just out the head lights back in and the front mount back on.i am also refinishing the wheels for my BMW as well.
here are the wheels i am refinishing. i have 2 done now i just need to dig the other 2 out and start on them. someone hit a curb hard with them i got most of the curb rash out but there are still some spots. it dose not bug me i got the wheels for $100 i will run them tell i find what i really want and sell them or use them as winter wheel.
08 silverado max
PostPosted: Fri Mar 21, 2014 2:22 am
well today i got the block back together just need to finish up the head and the motor will be ready to go back in the car.
08 silverado max
PostPosted: Fri Apr 04, 2014 12:41 am
i picked up a 2g head and sent it off to the machine shop so i am waiting for them to be done with it.
08 silverado max
PostPosted: Fri Apr 04, 2014 6:43 pm
I'm really digging those wheels!
PostPosted: Fri Apr 04, 2014 11:34 pm
thanks man :drinkers:
08 silverado max
PostPosted: Fri Apr 11, 2014 12:15 am
i got the head back yesterday and today i got it installed.now it is time to get the new lifters, cams in, and do the timing.
08 silverado max
PostPosted: Fri Apr 11, 2014 10:00 am
Looking good. Let me know when you plan to do the timing, I'll supervise. :wink:
PostPosted: Mon Apr 14, 2014 11:39 pm
well got the cams back in i will be doing the timing some time this week or maybe this weekend if you want to come over. I need to get the 2g intake manifold cleaned up and put back on along with the oil pan witch i will do this week as well i think.
08 silverado max
PostPosted: Tue Apr 29, 2014 11:50 am
How is the fit looking on the front wheels? Did you ever get around to pulling the front fender and lowering the car down?
