It is currently Sat Jun 15, 2024 4:53 pm
 Post subject: Transmission question
PostPosted: Sun Feb 09, 2014 11:50 am
I'm building a 89 colt GL, and I have a 7 bolt 4g64 with a 2g head setup, would the 4g15 transmission work with it? If so, which 7 bolt flywheel do I need? Which clutch choices would I be able to use?
Thanks
89 Colt - 2.4 4G64 in progress.
98 TSi AWD - 2.0 Manley Setup with a GT42r
91 Colt - for sale (shell)
95 p38 range rover - LS1 swapped ;)
PostPosted: Sun Feb 09, 2014 12:04 pm
Yes the transmission will bolt onto your 7 bolt block.
I have no idea what flywheel or clutch you would use. If you were to find a km210, which is the OE trans for the Colt/Mirage Turbo, you should be able to use a GST(FWD) turbo flywheel and clutches.
My opinion: you probably will not be able to use the 4g15 transmission with a 7 bolt without having a flywheel custom made. And given the diminutive size of the 4g15 flywheel and small clutch/pressure plate choices you will be fighting clutch slip.
PostPosted: Sun Feb 09, 2014 12:56 pm
Thanks for your help. I was going to pick up a 2g transmission but wanted to make sure if I can use a 4g15 without much headache. Well I'll just sell the 2 colt transmissions I have for the 2g transmission.
Last edited by Fastlife Garage on Sun Feb 09, 2014 1:11 pm, edited 1 time in total.
PostPosted: Sun Feb 09, 2014 12:58 pm
Which two CSM transmissions do you have?
PostPosted: Sun Feb 09, 2014 1:17 pm
A 91 and a 89, both from Plymouth colt GL hatchbacks. The transmission part number I can post that later today
PostPosted: Sun Feb 09, 2014 1:30 pm
That's okay. Some of the '92 Sedans have stouter transmissions with larger bell housings that are either the same as or very similar to non-turbo 1g DMS transmissions. But your two are not from a '92 so no dice!
PostPosted: Sun Feb 09, 2014 1:40 pm
Ok Gotcha! Thanks.
PostPosted: Wed Feb 12, 2014 1:29 am
Don't forget to update your profile with location, btw i would recommend you to get a turbo transmission, if you can't a f5m31 will do the job too...
PostPosted: Wed Feb 12, 2014 2:13 am
I don't recommend using the 4g15 tranny for anything more than stock 4g15 power, MAYBE n/t 63 power. The clutch is just tiny. When I bought my current CSM, the guy had a 63t swapped in using the 15's tranny (the "halfass" swap). As soon as it saw even a few psi of boost, the clutch would go up in smoke. That tranny went into the scrap pile as soon as I got it home and a proper f5m33 went in.
PostPosted: Wed Feb 12, 2014 10:30 am
You need a 92.5-94 FWD NA DSM flywheel. Like mentioned above though, if this is going to be a turbo engine save yourself a headache and put in a better transmission from the beginning.
PostPosted: Wed Feb 12, 2014 3:18 pm
Owner/Admin
Fastlife Garage, please add your location in your user control panel. Site rules!
