It is currently Sun Apr 28, 2024 6:56 am
Post new topic  Reply to topic  [ 41 posts ]  Go to page Previous 1 2 3
 Post subject: Re: wet floor
PostPosted: Sun Aug 26, 2012 3:32 pm
Just had a couple of hours of rain and I can confirm that my drivers side floor is 100% dry :supz:
Now I've just gotta do the same thing on the passenger side, will try to take a photo of the split seam before I seal it up.
PostPosted: Tue Aug 28, 2012 5:58 am
I had the same issue in my first summit. It was the boot that the harness goes through in the driver side fender. I siliconed the crap out of the boot and it was fixed. No more wet floor. You have to take the fender off tho which sucks
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Tue Aug 28, 2012 5:06 pm
Yup I did this too, think there are a few pics on the previous page. Stopped some water getting in, but with my car it seemed to be coming in from EVERYWHERE :lol: I'm pretty sure i've done every fix by now - windscreen seal, harness boot, seam seal behind the dash, and the one that finally eliminated the last last bits of water getting in - the seam for the drain area above the harness boot (on both sides of the car) Now 100% leak free :D
PostPosted: Mon Sep 03, 2012 1:46 am
I'm getting water in myself... :x gonna try all the above. Wish me luck... :-?
PostPosted: Sun Jan 12, 2014 6:46 am
Same nightmare for my Lancer :(
Water comming from behind the ECU bracket, red circle
Fender removed
Not bad
Fixed with urethane
I'm waiting after rain now.
The Colt turbo is fixed on both side, also the wire loom seal
PostPosted: Mon Jan 13, 2014 8:39 am
I did the same fix, helped a little, but I still get water coming in :(
PostPosted: Mon Jan 13, 2014 1:28 pm
Seen to be good for the moment for me [-o<
PostPosted: Tue Jan 14, 2014 10:18 am
Same thing here. I am starting to think windshield seal.
PostPosted: Mon Jan 20, 2014 10:19 pm
I had this problem about two years ago and tore my car about to find out where it was coming from since I was getting puddles in my car. The water puddles up by your windshield wipers and then is supposed to drain down through your fenders and out the bottom of your car. It's a simple fix though. TAKE YOUR FENDER LINERS OUT AND CLEAN ALL THE LEAVES OUT OF YOUR FENDERS! I pulled mine out and there was a lot of leaves and gunk up in there blocking the draining spot. I haven't had a problem since. :D
1991 Plymouth Colt - Project
PostPosted: Tue Jan 21, 2014 11:10 pm
I removed the fender liners (and leaves) already since they scrubbed on my tires.
PostPosted: Wed Jan 22, 2014 2:41 am
Check under the hvac grille, passenger side of the firewall. It's where your hvac sucks air in and it has a drain that gets easily clogged by organic gunk.
Users browsing this forum: No registered users and 53 guests
