It is currently Thu May 23, 2024 2:11 pm
 Post subject: C52A/C53A
PostPosted: Tue Jan 21, 2014 12:58 pm
 Post subject: Re: C52A/C53A
PostPosted: Tue Jan 21, 2014 1:54 pm
Sweet engine pic, bro
PostPosted: Tue Jan 21, 2014 10:44 pm
First time I've seen the rubber grommets used like that, to vent the valve cover. Any cracking every happen from heat cycling or well, what product were they originally designed for? Curious!
PostPosted: Wed Jan 22, 2014 11:53 am
THANKS MAN..AS FOR THE GROMMETS AND CRANKCASE VENTS GO THERE FROM A 4.0 6CYL. JEEP I SEE THEM EVERYDAY HERE AT WORK AND NO PROBLEMS YET..
PostPosted: Wed Jan 22, 2014 1:28 pm
Where does the black hose that is attached to the rear grommet run to? And is the PCV valve still connected?
PostPosted: Wed Jan 22, 2014 2:44 pm
PCV IS STILL CONNECTED TO THE MANIFOLD AND BOTH HOSES ARE GOING TO THE INTAKE NO CATCH CAN YET.
PostPosted: Wed Jan 22, 2014 3:31 pm
I dig it, looks similar to mine.
PostPosted: Wed Jan 22, 2014 4:49 pm
Like the look, but I gotta say it. Shift key. :)
PostPosted: Sun Feb 16, 2014 4:42 pm
Why not using a catch can ??
PostPosted: Mon Feb 17, 2014 4:05 pm
so you just drilled/cut out two big holes in the valve cover?? id imagine at 20+ psi of boost those grommets will weap oil due to excessive crankcake pressure. Im sure the jeep they came off wasn't boosted.
PostPosted: Tue Feb 18, 2014 9:06 am
Well it looks like they are in the baffles so oil should be minimal. The holes are large so crank pressure will be fairly low plus the PVC is also still hooked up. I am interested to see how much oil is accumulating in the intake but I'm thinking it's not that bad, just residual, same as factory.
PostPosted: Tue Feb 18, 2014 8:02 pm
Whats up guys I had a home made catch can on it but didn't like the look l will post a pic. off the old setup..As you can see i left one of the hoses clear so I can keep an eye on how much oil is going threw it and not much at all.
PostPosted: Tue Mar 11, 2014 2:31 pm
yeah I find catch cans collect more water then anything else. (from condensation inside engine)
