It is currently Sat Apr 27, 2024 2:37 am
PostPosted: Thu Jan 16, 2014 1:08 am
Hey there.
Im in the process of lowering my car,
I bought some brand new springs and started taking the shock absorbers of (front and rear)
Now the only issue I have is if your looking at the shock from the top, there is a bolt that holds the whole thing together (without it the spring would shoot out)
How do I undo that bolt without the actual shock arm (that moves up and down... silver) turning. when I try to undo it it turns with the bolt...
How do I stop it turning I cant seem to find any other bolts or anything to grip with?
Was thinking of vice grips but that may damage the shockie?
Any info on this would be appreciated
PostPosted: Thu Jan 16, 2014 7:59 am
I use an air gun, make sure you have a spring compressor to do the job safely.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Thu Jan 16, 2014 8:38 am
^^^^^ What he said. compress the spring with at least 2 spring compressors. Then hit that bolt with a Impact gun and it will come off.
PostPosted: Thu Jan 16, 2014 11:11 am
I grabbed a spring compressor from Harbor Freight for less than $20. If you don't have an air gun wrap a rag around the shaft and clamp it with visegrips, just be careful not to scratch it up.
PostPosted: Thu Jan 16, 2014 4:27 pm
hey thanks for all the info.
Worked beautifully :)
PostPosted: Sat Jan 18, 2014 5:18 am
I always used the vicegrip trip that 89Mirageman mentioned until I got an impact. :fencing:
PostPosted: Fri Jan 31, 2014 4:18 pm
Ive had an impact still spin it round. . . A rag and a pipe wrench close to the top as you can get. Close to the top in case you dimple the piston rod.
Users browsing this forum: No registered users and 55 guests
