It is currently Sun Jun 09, 2024 2:48 pm
PostPosted: Thu Dec 05, 2013 3:46 pm
Had the iac cleaned and checked..still stalling.i ve been reading it could be a bov issue.could that cause the stalling?I am not running a bov at the moment could that cause this issue??
T
PostPosted: Thu Dec 05, 2013 3:52 pm
Does your car have a turbocharger?
PostPosted: Thu Dec 05, 2013 4:53 pm
Yes, its a 4g63 t engine
PostPosted: Thu Dec 05, 2013 5:01 pm
And you do not have a blow off valve?
PostPosted: Thu Dec 05, 2013 5:19 pm
At the moment no
PostPosted: Thu Dec 05, 2013 5:24 pm
....okay. So what did you do about the giant hole in your charge piping where your blow off valve used to be?
PostPosted: Fri Dec 06, 2013 12:30 am
I dont have the standard pipiing the engi e is fitted on a 91 lancer glx and its very hard to obtain parts in malta because the galant was not imported here nor was the colt gt so ypu have to make do.
PostPosted: Fri Dec 06, 2013 1:01 am
Understood. How about some good pictures of the engine bay?
PostPosted: Fri Dec 06, 2013 1:13 am
Go to the pics and vids thread if youd like anf some pics of my car.there is a pic there of the engine bay to get an idea.
PostPosted: Fri Dec 06, 2013 9:30 am
Ok, from those pics, you have no MAF, and no visible BOV.
I think there's something funny going on here...
PostPosted: Fri Dec 06, 2013 2:00 pm
You have a good eye!!i installed a maf senser since taking the pic.
PostPosted: Fri Dec 06, 2013 2:38 pm
Maf needs honycomb to straigten the airflow and get an accurate reading at idle
Any unmetered Ir leaks betweek maf and intake valves will cause rough running.
PostPosted: Fri Dec 06, 2013 6:23 pm
The honeycomb is there i also swapped the filter tp the one whoch came with the maf senser.i dont think it is awiring issue because at first it was ok,but then the problem with the stalling and high idle increased.
PostPosted: Wed Dec 11, 2013 11:30 am
Maybe it's a vacuum leak?
PostPosted: Sat Jan 11, 2014 10:31 am
Alright was this a 4g15 equipped car originally, and does it have the 4g15 fuel pump still installed??
No BOV?? Really ... you need to fix that for sure. Turbo will surge when shifting and cause issues with the intake charge on decel. Simple part to find overseas (US or anywhere) and install into a pipe inline. Then you run a vacuum line from the BOV port up to your intake manifold port, likely one of the larger copper looking ones. Do you have functioning block off rubbers on the extra ports on the intake manifold right now?? If they crack with heat and time, they will leak for sure!
Okay, for stalling and high idle, there were lots of tips posted in your thread, from a while back. I just read over them again.
Have you got coolant hoses running to the throttle body and back to the heater core on the firewall?? Has the cooling system been bled of any excess air bubbles and do you get really good heat from the dash with the engine hot and the engine at idle??
Suspect parts - Idle Stop Switch on top of the TB, was it confirmed to make a ground contact and is the little plate in place from the screw on top of the TB to the nut/bolt that is one of the four that hold the TB in place? That metal plate gives a ground path back to the engine/firewall for the ISS. Very important to have that checked.
Next is the ISC, but you had that cleaned and likely it OHMed out okay with a multi-meter/DVOM (digital volt/ohm meter).
As Crackerman posted, you need to check the FIAV operation, it could leak internal to the TB which means pulling off the big plate on the bottom of the TB. There is a gasket that can crack in that area and leak vacuum and then boost when the turbo is spooling/spooled.
Here is a 91-94 DSM style o-ring for reference: https://www.rtmracing.com/xcart/product ... 603&page=1
Do you have a Palm Pilot or small logger tool that can show you the data coming from the datalogger port on the car?? This is very helpful to see where the ECU thinks everything is set to. We can then determine where the TPS sensor is set (is it within the factory range for idle and does it see WOT wide open throttle when pedal is fully applied), and many other variables.
Timing - was this set with the firewall harness plug grounded, and the datalogger pin at the port inside the car, grounded also, AND the engine coolant near full operating temperature?? Does the car have a proper OEM thermostat installed ?
Once we know all of this, we can find out more.
P.S. What is the vacuum you get at idle, cold and hot.
