It is currently Sat Apr 27, 2024 7:15 pm
PostPosted: Sun Sep 01, 2013 1:15 am
Hi! im pretty sure i need a tach filter in order to get my tach working, so im having hard time trying to find one locally could somebody tell me which other cars comes with them?
PostPosted: Sun Sep 01, 2013 2:16 am
90 dsm.. eclipse..talon..laser
are your electronics from a 90?
PostPosted: Sun Sep 01, 2013 2:50 am
Yeah they're, so pretty much 90' dsms only? Any other Hyundai maybe or Mitsu?
PostPosted: Sun Sep 01, 2013 8:40 am
92-95 Elantra and early Sonatas although I'm not sure what year models on those.
PostPosted: Mon Sep 02, 2013 6:25 pm
Thanks guys! well i got one from a 1995 Hyundai Sonata and same thing, replaced and no tach working, i can't get it look if i connect the 109 wire to the red or white wire coming to the tach filter my tach moves but not correctly, so if i connect the wire to the out signal wire of the filter (yellow) nothing happens...
PostPosted: Mon Sep 02, 2013 8:35 pm
Two of the wires go to the coils which I'm sure you know. The other I believe goes to the tach wire over on the P/S kick panel. I'd run it completely separate and not tie into the dsm engine harness anywhere. Hope this makes sense.
PostPosted: Mon Sep 02, 2013 11:46 pm
Thanks for the pic, and yeah thats the way i have mines, so in this picture the yellow wire goes to the tach wire on the kick panel right? well im pretty sure thats the way i did but my tach did not move, so right now im taking the tach signal from the white one thats why my signal isn't correct, i check tomorrow once again...
PostPosted: Tue Sep 03, 2013 8:14 am
But is it going through the dsm engine harness or straight to the tach wire on the cluster?
PostPosted: Tue Sep 03, 2013 7:56 pm
Output tach filter signal straight to the cluster pin on the C-19, but still not working, if i get the signal straight from the coil the tach works but not correctly, so im assuming i got another non working tach filter, what do you think? i tried 2 the 90' and the 95' from the sonata
PostPosted: Wed Sep 04, 2013 12:38 am
I had to wire this for my tach to work. I actually have no idea what it was.
89' Mitsubishi Mirage Turbo.
PostPosted: Wed Sep 04, 2013 1:09 am
thats the noise filter, i have it connected on my IM, how did you wire it to your tach?
Users browsing this forum: No registered users and 56 guests
