It is currently Sun Apr 28, 2024 11:20 pm
PostPosted: Mon Jul 01, 2013 8:32 pm
I read somewhere once that if you have an original 89-92 colt/mirage turbo transmission you could use the all wheel drive dsm flywheel. Is there any truth to this?
PostPosted: Mon Jul 01, 2013 9:27 pm
It's the 6 bolt FWD Turbo flywheel/clutch you want.
PostPosted: Tue Jul 02, 2013 1:16 am
It is possible to use an AWD flywheel with FWD transmission.
My friend has it on his silver Colt.
AWD flywheel is a bit smaller then FWD one.
I remember he had some problems getting it started, because the flywheel was grinding against something..
But ones he got that done, works good.
PostPosted: Tue Jul 02, 2013 7:28 am
AWD fkywheel is 106 tooth. FWD is 110 tooth. The starter will grind away and become useless. As stated above, use the FWD flywheel
PostPosted: Tue Jul 02, 2013 10:02 am
I think Boostfreak has a thread on here somewhere about this. He notched the bolt holes for adjustment I believe. Never tried it myself but I'm sure its possible. I'd just grab the FWD one since they are cheap and plentiful.
PostPosted: Wed Jul 03, 2013 7:09 am
ok so a fwd dsm flywheel will work with my original colt turbo transmission? im asking because since the original colt turbo flywheel is differant from the fwd dsm one i have. and when i started looking up part numbers i keep getting a differant part number between the colt and dsm clutch. and the colt clutch disc appears smaller.
PostPosted: Wed Jul 03, 2013 7:11 am
I think stock Colt uses 215mm diameter clutch and Eclipse uses 225mm.
Aldo it would be easier to talk with transmission numbers then FWD this and that..
PostPosted: Wed Jul 03, 2013 7:30 am
ok ill get the numbers off the transmission tonight
PostPosted: Wed Jul 03, 2013 9:35 am
Yes, the FWD 6-bolt DSM flywheel will fit in your original colt turbo transmission. You will need a DSM turbo clutch (225mm). Everything else bolts up.
PostPosted: Wed Jul 03, 2013 11:22 pm
thanks CaptainTonus for the help
PostPosted: Thu Jul 04, 2013 12:48 am
No prob! Please put a location in your profile, as per the site rules. Also, post up some pics of your cars in the members section. We like pics. :P
