It is currently Sun Jun 16, 2024 11:18 pm
PostPosted: Wed May 22, 2013 6:36 am
I have a chipped tooth on fifth, and need to know what other options work for a fifth gear/matching gear set, will work. If there is a fifth other than the FWD f5m33 from a DSM, that would be my reason for asking.
PostPosted: Wed May 22, 2013 6:53 am
I heard something about people putting EVO 3 5th gear into F5M33...
Not sure about details..
Found this in 2sec search on google..
http://www.dsmtuners.com/forums/newbie- ... gains.html
Aldo I dont have time to read it now. Try to research :)
I heard is taller gear so that should be good for highways cruise.
Only down side could be cost of it.
PostPosted: Wed May 22, 2013 6:54 am
Evo3
http://www.jackstransmissions.com/colle ... i-5th-gear
Or a double synchro option
http://www.jackstransmissions.com/colle ... o-gear-set
PostPosted: Wed May 22, 2013 8:31 am
The AWD 5th gear is supposed to be higher, giving you a lower RPM at cruise.
PostPosted: Wed May 22, 2013 11:55 am
So 5th gear set from what year AWD will drop in where the FWD 91 unit sits now?
No mods?
PostPosted: Wed May 22, 2013 12:31 pm
Supposed to be interchangable, just a taller gear. Put a FWD 5th in an AWD and you would never need to downshift to build boost!!
PostPosted: Wed May 22, 2013 9:59 pm
Jacks shows FWD 92-99 and all AWD as compatible for the taller 5th.
I have a 91 gear set. I may have a local option to compare with, I'll find out shortly.
If I know that 91 FWD DSM transmissions will accept this taller fifth, I may have two options for sourcing gears.
PostPosted: Sun Jun 16, 2013 9:22 pm
All 1g 5th gears will interchange. I ran a 5th from a 93 in my 90. Worked out great and dropped around 3-500 rpm cruise speed.
PostPosted: Mon Jun 17, 2013 12:48 am
Thats good to know! :) I guess I'll be looking for a 93!
Thanks for the good info!
~Ken
'91 Colt - Ongoing work in progress.
http://4g61t.org/forum/viewtopic.php?t=37446
^Check Build Thread^
'82 Chevy El Camino Tow Veh. for my 2012 Skyline Koala 24' Travel Trailer
'06 Chevy Aveo - Daily Driver until Colt is back up and running!
PostPosted: Mon Jun 17, 2013 2:01 pm
or find one from any 1st gen...
90, 91, 92, 93, 94
as long as it says w5m33, you are good...
PostPosted: Mon Jun 17, 2013 3:34 pm
Good info, thank you.
PostPosted: Mon Jun 17, 2013 4:04 pm
Flying Eagle keep us posted on your finding also. I been really want to change 5th in my fwd talon for years just to help the mpg over the road.
92 Colt GT 4G63t
92 Summit TSI AWD 4G63t Auto
5 X 90 Talon TSI
90 GSX
PostPosted: Thu Jun 19, 2014 11:25 am
Old post, but I will be doing this before the SO this year. I hate buzzing around at near 4k to keep up with everyone. The reason Jack's lists 92-94 transmissions is because they are stronger. You should be able to grab the gears and parts at the end of any 1g AWD transmission and slide/nut them onto a 90-94 FWD transmission. I will really enjoy the 3-500 rpm drop. We have an AWD tranny with a blown center-diff that will be donating it's 5'th gear set to the bird.
PostPosted: Thu Jun 19, 2014 1:24 pm
I need to jump on this taller 5th bandwagon.
PostPosted: Thu Jun 19, 2014 1:42 pm
I had a taller 5th gear on my Mirage. I honestly didn't like it. It was a F5M33 trans with a AWD 5th gear, which is a direct bolt-in affair. It lowered the RPM's so much that the car fell of its powerband in highway cruising, and I had to give it a lot of gas to pass people and things like that. The fact that the engine was lugging out of its powerband, and the fact that I had to give it more throttle to get around things, meant that my gas mileage didn't really improve any, if at all. I honestly hardly noticed a difference from the stock KM210. The F5M33 trans I installed already had the AWD gear put in when I installed it, so I can't tell you what the normal F5M33 5th gear was like. I will admit, it is nice cruising at lower RPM's in general. It's less noisy and vibrationy, but that's about it.
