It is currently Sun Apr 28, 2024 8:25 am
Post new topic  Reply to topic  [ 53 posts ]  Go to page Previous 1 2 3 4
PostPosted: Mon May 21, 2012 1:57 am
hola jhon,,,, vendes algunas piezas??
PostPosted: Mon May 21, 2012 11:44 pm
Well I may have prematurely written this one off. Its still in the drive way and over the weekend I went to pull a clip off it for my 3G. Then, 'FACEPALM'! :bloaty:
Note to self, when doing a MPI swap on these cars be sure to zip tie any loose cables.
Apparently what I thought was the sound of internal motor parts bouncing around was actually the sound of an SD harness getting wrapped up on my passenger side axle. Ripping it apart and partially ripping the engine harness apart.
Tomorrow I hope to pull the harness and assess and repair. Gotta stock up on solder and heat shrink...
This car is fairly straight but does have rust. I wont be using it too much longer if anyone wants anything off it let me know....
PostPosted: Fri May 25, 2012 1:48 am
I might have to nab some parts from you interior wise since you have the same gray interior as I do. Hopefully it will run though after you fix it. Might be able to stretch its life
-2014 Subaru BRZ Limited
PostPosted: Thu Oct 25, 2012 8:07 pm
if you do end up parting it out, i would love the deck lid chrome rack!
12 dodge charger hemi r/t max
08 r6 modded on e30
89 mirage turbo 4g63t - fast
88 dodge colt 4g32bt - project daily driver
PostPosted: Thu Oct 25, 2012 8:42 pm
Sorry I swapped that lid out a few years ago. I have seem them at the wreckers though.
I'm still driving it for the time being. That may change soon. I'll keep you updated.
H
PostPosted: Mon Nov 05, 2012 7:35 pm
I just picked up another car to DD. This one will be no more soon. I will be pulling some bits to keep like the WB 02 and eprom. I anyone wants anything let me know.
PostPosted: Sat Nov 17, 2012 12:25 pm
Ok guys, I'm working out of town for a week or so. After I get back this car will get dismantled. The parts that are I will keep.
  • LC-1
    EPROM
    ostridge
    Wally
    MX6 IC
Parts that may be of use to someone but require labor.
  • ACT PP & Clutch
    TD04 13G rotated
    MPI Setup including 4g37 manifold with with 60mm TB
    modified 4g63 SOHC distributor - provides CAS/TDC Signal for MPI setup
    Good head
    Full c13 sedan interior including starion steering wheel
    1G DSM Engine loom fitted to c13 dash loom and C13 MPI relay.
It will be going to the crusher soon. I'm in Canada and shipping this to the US is very viable; I don't expect much interest.
PostPosted: Sat Nov 17, 2012 2:59 pm
man, the whole top end w/turbo and all sounds very tempting!! too bad your in canada...
08 r6 modded on e30
